Author Topic: groovymame and resolution  (Read 3452 times)
limner
  • Last login:June 08, 2015, 06:59:42 pm
« on: June 05, 2015, 09:00:22 am »
hi
i'm using groovymame with mame 0.155b and a WG D9400 monitor arcade
i've noticed that somethimes the resolution used is not exact the original used by the chosen game but close to it: is it possibile to use always the exact resolution?
haynor666
  • Last login:November 21, 2025, 05:45:00 pm
  • retro maniac
Re: groovymame and resolution
« Reply #1 on: June 06, 2015, 01:28:55 pm »
That depends. Some resolutions like 256x256@60 are impossible to set on typical arcade monitors. With what games you have problems ?
  • Last login:Today at 09:42:43 am
« Reply #2 on: June 06, 2015, 05:24:43 pm »
Is it 224p vs 240p what you're concerned about?
limner
« Reply #3 on: June 08, 2015, 07:47:56 am »
i don't know if it is an issue or is something that can't be fixed but as example
1) d&d shadow over mistara
Video 384x224
Switchres 384x240p
2)demon frost
Video 448x224
Switchres 448x240p
Those are only a couple of exaples where Video is not equal to Switchres....maybe is it normal?
adder
« Reply #4 on: June 08, 2015, 07:59:01 am »
hello limner this is normal and expected behaviour for switchres to choose a 240p mode when a 224p game is run. don't worry, there is not any unwanted scaling going on (and if there is, it is easily resolved!) :)
limner
« Reply #5 on: June 08, 2015, 08:28:10 am »
ah ok
are there any resolutions that should be added manually?
i only installed groovymame and crt_emudrive....this is the first time i use those tool so i would like to understand if there is more that can be done in order to use my hardware (an arcade monitor Wells Gardner d9400)
adder
« Reply #6 on: June 08, 2015, 09:53:51 pm »
I would recommend reading this documentation at the link below to familiarise yourself with groovymame and crt emudriver:
http://geedorah.com/eiusdemmodi/forum/viewforum.php?id=1
big10p
  • Mmmm, arcade classics!
« Reply #7 on: June 11, 2015, 11:05:02 am »
GM is running my 224 vertical games at 256 vertical res. I have a 240 res mode defined and working. Should GM be choosing the 240 mode instead?
« Reply #8 on: June 11, 2015, 11:52:55 am »
Yoy have an horizontal monitor don't you?
« Last Edit: June 11, 2015, 11:55:15 am by Calamity »
big10p
« Reply #9 on: June 11, 2015, 12:05:19 pm »
Yes I do. Ignore me, I got the H and V res mixed up.  :-[
I've just been trying to get Scramble to work without glitchy scrolling, which it does at native 256 vertical mode (on my horizontal monitor).
« Reply #10 on: June 11, 2015, 12:09:03 pm »
Force -syncrefresh for that game. It will run smooth but slower. Or try -monitor arcade_15ex
big10p
« Reply #11 on: June 11, 2015, 12:16:53 pm »
I'll give that a try. Thanks as always, Calamity.  :)
big10p
« Reply #12 on: June 24, 2015, 09:41:48 am »
I tried forcing syncrefresh but am still getting glitchy scrolling. MAME does report the game is running at 99% as expected, though. I even tried forcing waitvsync but the glitching persists.
big10p
« Reply #13 on: June 25, 2015, 11:21:11 am »
OK, the glitchy scrolling was caused by having frame delay set to 4. Set it back to 0 and now scrolling is silky smooth.  :)
