Author Topic: Well Gardner 4600  (Read 1318 times)
bsholbrook
  • Newbie
  • Last login:December 30, 2003, 08:56:05 pm
Well Gardner 4600
« on: December 30, 2003, 09:01:14 pm »
I recently acquired a complete upright Centipede cabinet with the original WG 4600 series monitor.  The monitor will not display a picture until the cabinet is powered on and warms for 2-3 minutes and then power is restarted.  After the initial warmup and restart the monitor works great and has a great picture.  Previous owner indicated that the monitor would come on sometimes but then got worse over time to the point its at now.
I have a new CAP kit on the way, I was hoping someone with more knowledge might have some idea if this will solve the issue or if something additional should be done?  The warmup followed by a restart seems to work without failure, any suggestions would be greatly appreciated,
Ken Layton
  • Guru
  • Technician
Re:Well Gardner 4600
« Reply #1 on: December 31, 2003, 12:48:32 am »
Yup, capkit should fix it plus check the main board for numerous cold solder joints.
