Author Topic: Sega Model 2 in Maximus Arcade HELP!!! (AIMTRAK)  (Read 2373 times)
nightshift84
  • Last login:June 02, 2015, 09:35:59 am
« on: June 02, 2015, 04:42:30 am »
Hey Guys
Im really hoping someone can shed some light on an issue im having.
Sega Model 2 works fine with lightguns as a standalone however in Maximus  Arcade as soon as i click the trigger the screen turns black and only sound can be herd.
Im guessing this is because the gun acts as a mouse and the trigger button is acting as left mouse click which causes Maximus to have some sort of brain fart.
Im hoping its something fairly obvious and im just being a bit of a thicko duhhhhhhh  :dizzy:  :tool:
thomas_surles
Re: Sega Model 2 in Maximus Arcade HELP!!! (AIMTRAK)
« Reply #1 on: June 02, 2015, 07:34:46 am »
Hmm I'm not sure since I don't use lightguns, but it sounds like a setup issue. Go into preferences and check your mouse settings. If everything is fine there then I have no clue.
nightshift84
« Reply #2 on: June 02, 2015, 08:52:07 am »
Thanks for responding however ive tried that bud with no luck at all. Ive tried mouse enabled and mouse disabled and both do the same thing  :dunno
Ive made a short video explaining my issue  :hissy:
Just to add i have no mouse keys set as MA interface buttons i.e "quit executable" #Confused
« Last Edit: June 02, 2015, 09:00:37 am by nightshift84 »
TapeWormInYourGut
  • Last login:August 17, 2025, 06:31:27 pm
« Reply #3 on: June 02, 2015, 07:14:25 pm »
Do you already have the full-screen fix installed on the M2 emulator for gun games?
http://forum.arcadecontrols.com/index.php?topic=121412.0
Sometimes the emulator will minimize without. My only guess is that it minimizes and the black screen is MA. I don't use MA though, so it is just a thought. I had the M2 minimize problem and needed that fix to stop it from happening.
Since it works fine outside the emulator then maybe that is not the problem.
