Author Topic: The Timemachine / Tidsmaskinen [DK] (Bartop W. Raspberry PI2)  (Read 1858 times)
Anderss
  • Last login:May 27, 2015, 03:04:59 am
Hi,
Welcome to my project called "The Timemachine", in danish "Tidsmaskinen".
This is my first project and i have decided to go for a bartop with a raspberry pi 2.
Setting up the RPI2 - i have absolutely no clue what i am doing  :laugh:
Start making a temporary control panel for proof of concept
assembling buttons
wirering
Tadaaaa - Doesent work with retropie
NVM - starting wood work
Finishing woodwork and plexi cutting
The final result of a days work in the woodshop
Started sanding and filling cracks
« Last Edit: May 26, 2015, 02:46:47 pm by Anderss »
MacGyver
  • Last login:December 18, 2023, 12:49:00 am
    • Project Build
Re: The Timemachine / Tidsmaskinen [DK] (Bartop W. Raspberry PI2)
« Reply #1 on: May 26, 2015, 03:42:39 pm »
Looks great so far.  :applaud:
I'm curious about the RPI2, what is the newest machine it can play full speed?  What frontend are you planning on running?   Are there weird considerations with the control's wiring?
Donkey_Kong
    • CNC Machines
Anderss
« Reply #3 on: May 27, 2015, 02:42:55 am »
Macgyver
Thank you. I'm planning on using retropie. As far i am concerned n64/ps1 can run on a rpi2.
I Wont be running Anything fancy, newst machine that i have planned on running is snes.
And about the wirering. I have no clue what i did, i just followed a guide. Thats probably why it looks messy. I found the wires to be a little short though. This was just my prototype panel layout so i Will try doing better on the final.  :D
Donky: thanks for the link, i Think the Tiny LCD hdmi screens Can be useful for future projects.
Question
Di you guys have any ideas on a control panel to handle snes/genisis/saturn/nes/a couple of arcade classics ?
« Last Edit: May 27, 2015, 03:04:59 am by Anderss »
reptileink
  • An 8 bit hero
« Reply #4 on: May 27, 2015, 09:42:55 am »
From the games listed, SNES is the only one with the most buttons (6), so I would at least use a minimum of 6 buttons. I had the SNES advantage stick back in the day and would use it for fighting games so all three buttons were laid out and I didn't have to use the shoulder buttons.
