Author Topic: Rowe Ami R80 Info  (Read 2190 times)
aussieamusmenttech
  • Last login:May 20, 2015, 02:57:35 am
  • I want to fixit
Rowe Ami R80 Info
« on: May 18, 2015, 02:48:53 am »
Hi guys new to forum, Hello everyone thanks for letting me join. Been in the amusement business in Queensland Australia since mid 70"s, I've been given a R80 jukebox to repair and the junction box tranny has given up the ghost, and has been a long time since I've worked on one, can someone tell me what is the secondary voltage output for the solenoids. Any help would be appreciated. Dave
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe Ami R80 Info
« Reply #1 on: May 18, 2015, 06:44:47 am »
Hi Dave,
Welcome to the forum.
I can supply you with a complete power supply/junction box (110 volt or 220 volt) or if you prefer just a transformer of either voltage.
Regards
Alan
Alan Hood
ami-man
UK
aussieamusmenttech
  • I want to fixit
« Reply #2 on: May 19, 2015, 01:05:12 am »
Thanks Alan, I should have typed in a G80 box not R80, the tranny is 240v and the customer doesn't care whether its genuine so I could maybe put the new tranny under the old tin cover of the original, just need to know the voltage 36v seems to ring a bell. What sort of cost plus freight Thanks Dave
ami-man
« Reply #3 on: May 20, 2015, 05:51:59 am »
Hi Dave,
The G80 makes it somewhat different.
The junction box on the G80 just provides 117 volts for the amplifier, lights etc and it has a DC supply that is provided by a selenium rectifier the maximum open circuit voltage is 32 volts, these rectifiers in practice supply between 25 1/2 - 29 volts DC. Both DC circuits are protected by 8/10 amp (800ma) slow blow fuses and the supply voltage at 8 amp.
It might be worth having a word with Erwin Boot in Tasmania to see if he has an older  power supply lying about all of the junction boxes from the MM-1 through to R-80 will have a DC supply of 30 volts that you could use.
Regards
Alan
Alan Hood
ami-man
UK
