Author Topic: GroovyArcade installation error  (Read 2221 times)
big10p
  • Mmmm, arcade classics!
« on: May 15, 2015, 07:37:39 am »
Thought I'd give GA a whirl but get this error on installation to a new 8GB USB flash drive:
INFO: task extlinux: 2011 blocked for more than 120 seconds:
Tainted: G I 9:17:6-1-GA #1
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message
Whatever the hell that means. I can't type the echo command line as the characters that appear when I type bare no relation to the actual key I'm pressing!  :dunno
I've followed all the steps in this tutorial:
https://code.google.com/p/groovyarcade/wiki/USB_installation
Any ideas?
Cheers.
big10p
Re: GroovyArcade installation error
« Reply #1 on: May 17, 2015, 07:20:43 am »
No-one else had this error?
Think I'll get myself a new hobby, lol. I spend 98% of my time trying to get things to work!  :banghead:
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
« Reply #2 on: May 17, 2015, 01:14:04 pm »
I used to get this error with slow USB drives.
big10p
« Reply #3 on: May 18, 2015, 06:36:02 am »
Interesting - thanks for the reply. The stick is brand new and a good make so not sure why it doesn't work.
adder
« Reply #4 on: May 18, 2015, 09:23:35 am »
I have found that a lot of usb sticks even if they are sandisk or kingston are quite slow these days (china mass production etc). could you use a portable external 2.5" hdd instead? that would be quite a bit faster. you can get a used 80gb 2.5" hdd for under £10 on ebay, and a new 2.5" hdd usb enclosure for around £4
  • Last login:Today at 04:52:46 pm
« Reply #5 on: May 18, 2015, 12:17:46 pm »
Hi big10p,
I've never seen that exact issue. However I no longer recommend installing GA in an USB, since my bad experiences with it. The file system is extremely fragile and you can loose all your data by simply removing the pendrive a fraction of second before you're supposed to. It's way better to use a proper HD.
(probably I should modify my signature)
big10p
« Reply #6 on: May 18, 2015, 01:12:34 pm »
OK, thanks for the info, Calamity. And thanks, adder - looks like your suggestion is a good one.  :)
