Author Topic: SDLMAME + GLSL on Linux = hardware performance  (Read 1394 times)
spider75
  • Last login:May 18, 2015, 01:21:55 pm
« on: May 13, 2015, 10:01:01 am »
Hi Guys,
Sorry if this has been already debated, but I tried to search the topic and didn't find anything.
I'm building a bartop arcade cabinet (very slowly, but it's fun thing to do it with my 5yo son) and it's time to choose the hardware.
I am really thrilled by the GLSL effect so I'd like to use them. I've tried the "standard" CRT ones, and the Lottes shader (http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=330562&page=0&view=expanded&sb=5&o=&fpart=1&vc=1)
The performance on the laptop I'm using for prototyping the software are really really slow.
I was wondering which is a good combination of CPU/GPU I can use for this configuration.
I'm not planning to put PSX2 or Dolphing game on it, I'd like to stick to arcades and maybe some 8/16bit console, so I'd like to not waste money to build an overkill system, but still I'd like to play most Mame game with the GLSL shader.
At the moment I was thinking of these two configuration:
* AMD 5350 + a discreet GPU like GTX 560 which I could find used for not much money
* AMD A10 7850, which has a in-chip GPU of the R7-250 kind (more or less)
Any experience?
nitrogen_widget
  • Last login:November 19, 2025, 07:10:59 am
Re: SDLMAME + GLSL on Linux = hardware performance
« Reply #1 on: May 13, 2015, 12:49:48 pm »
I can run the CRT shader on a radeon HD 4650, 3 ghz single core celeron D on 64 bit linux at 100% on 1280x1024 4:3 LCD panel for most non 3d games.
3-d fighters like jojo's venture ran at %80.
However, I never checked to see how it ran without the shader so it could just be the cpu wasn't up to it because it is old & weak compared to today's bargain bin CPU's. :)
meestermole
  • Last login:November 16, 2023, 01:04:35 pm
« Reply #2 on: May 16, 2015, 12:16:46 am »
I can confirm that most 80s classics will run with a Dell Optiplex 755 Core 2 Duo, 2.6Ghz, 4GB DDR2 with an ATI 3200(?) - post SFII fighters tend to suffer a bit on my setup, however
