Author Topic: Preset for CRT TV (1080i, 480p and 576p)  (Read 2282 times)
ID4
  • Last login:January 29, 2025, 02:55:51 pm
    • ID4 Retrodev
« on: April 30, 2015, 05:16:04 am »
Hi
I have an CRT that workd at 1080i, 480p and 576p.
What can be the crt_range for this CRT?
  • Last login:Today at 09:42:43 am
Re: Preset for CRT TV (1080i, 480p and 576p)
« Reply #1 on: April 30, 2015, 07:57:46 am »
Hi ID4,
Assuming it's 576p@50 Hz (31kHz), you can just take the arcade_31:
crt_range0  31400-31500, 49.50-65.00, 0.940, 3.770, 1.890, 0.349, 0.064, 1.017, 0, 0, 400, 512, 0, 0
...and do these changes:
crt_range0  31400-31500, 49.50-65.00, 0.940, 3.770, 1.890, 0.349, 0.064, 1.017, 0, 0, 400, 576, 800, 1152
(yes, it will handle 1152i@50Hz too)
ID4
    • ID4 Retrodev
« Reply #2 on: May 01, 2015, 04:36:26 am »
Hi ID4,
Hi Calamity!
Thanks you! Really it supports 50 and 60 Hz modes at 1080i. 480p and 576p are supported too as I said.
This CRT supports 576i and 480i too, but it scales to progressive so quality is lost.
« Reply #3 on: May 01, 2015, 02:25:19 pm »
If you want 1080i@ at 60 Hz you'll need to increase HfreqMax a bit in that crt_range.
Yeah that's because it the TV works at 31 kHz natively so it needs to upscale 15 kHz signals.
ID4
    • ID4 Retrodev
« Reply #4 on: May 02, 2015, 12:14:45 pm »
I know It, thanks you Calamity, please take a look to you gmail account.
« Last Edit: May 02, 2015, 01:16:16 pm by ID4 »
