Author Topic: Taito All in one  (Read 1465 times)
reptileink
  • An 8 bit hero
Taito All in one
« on: May 06, 2015, 01:36:03 pm »
Have a bead on a Taito Gameroom Classics on CL. Guy is asking $220 for it. Only two pictures, but it looks like it's in great shape. Wondering if I should grab it? (Mind you, I have no need for a new cab, but then again, why does that matter?  :cheers:
Just wondering if it's a good grab (should it still be available?) I'm sure it's probably gone as it's been up there for a couple days.
Listing:
Taito standup arcade plays lots of great Taito classics!
« Last Edit: May 06, 2015, 01:39:29 pm by reptileink »
RetroGreg
Re: Taito All in one
« Reply #1 on: May 06, 2015, 02:00:24 pm »
I'd jump on that. Looks pretty decent for $200.
reptileink
  • An 8 bit hero
« Reply #2 on: May 06, 2015, 02:09:36 pm »
The big question is, keep it as is, or convert it into something else?  :dunno
JimmyU
  • Last login:July 28, 2025, 08:19:07 pm
  • I believe I can fly!
« Reply #3 on: May 06, 2015, 03:31:33 pm »
I would say keep it as is. There are a lot of fun games on that board.
reptileink
  • An 8 bit hero
« Reply #4 on: May 06, 2015, 03:37:44 pm »
Well, I have another bead on a Carn-Evil game that is claimed to be running perfect for a LOT less money than this one. The guy said he had a lot of inquiries, but nobody has come to get it. It's about an hour away or so, my only issue is I only have a mini-van and want to make sure it's going to fit. Also, can I lay it on it's back?
Franco B
« Reply #5 on: May 06, 2015, 03:45:16 pm »
Jump on it. You can sell the PVGTech Taito Multiboard for over £300/$450 on its own.
mytymaus007
« Reply #6 on: May 06, 2015, 06:34:15 pm »
I came across one of these, once I looked at it I walked away. the marquee is a sticker so u would need to cut if you want to add lights. The wood used is light particle board and the control panel is fixed so no easy modification. Its not really an arcade cabinet. Every aspect is bottom of the line.
  • Last login:Today at 01:02:43 am
« Reply #7 on: May 06, 2015, 08:36:27 pm »
Franco is right- the board itself is worth more than the cab.
Mr_Numbers
  • Last login:December 01, 2017, 10:49:05 am
  • Long time lurker, first time builder
« Reply #8 on: May 06, 2015, 08:48:03 pm »
From the other opinions it sounds like you buy it, keep the Taito board, monitor and junk the cab.
RetroGreg
« Reply #9 on: May 06, 2015, 11:14:09 pm »
Well that's a bummer the cab sucks. Can't really tell from the pic. Well. It can't be as bad as those Midway cabs from a few years back. I always laugh when I see those on Craig's List. They're terrible.
