Author Topic: Kortek MP-KT2182 from PGA Tour  (Read 1562 times)
lostboy4480
  • Last login:January 29, 2026, 12:27:18 pm
« on: May 04, 2015, 09:51:22 pm »
I am in the process of rebuilding a PGA Tour Cabinet, I have finished the Computer part so now it's onto the monitor.  This is something new to me but I want to learn as much as I can.
When I first turned it on, There was nothing on the display..  I could hear the static build on the screen but thats it.  I then found if I turn the Screen adjustment on the flyback I could get the following.
Is this vertical collapse ?
If I go a little further with the screen adjustment after this it all goes blank again.
Should I do a cap kit ? new flyback ? any advise on where to start would be greatly appreciated.
I have enclosed a few more pics if that helps.  It looks like it has had some of the caps replaced.
Cabinets
NBA Jam
Golden Tee 2005
PGA Tour Golf Team Challenge
Tekken 5: Dark Resurrection
Generic Taito (Project)
grantspain
Re: Kortek MP-KT2182 from PGA Tour
« Reply #1 on: May 05, 2015, 03:06:34 am »
i would be looking at vertical deflection circuit,kortek are well known for ic,resistors and caps in v.def circuit dying
i would not rule out an issue in the deflection yoke itself
lostboy4480
« Reply #2 on: May 08, 2015, 01:06:31 pm »
Thank you,  That will give me something to start on :)
Cabinets
NBA Jam
Golden Tee 2005
