Author Topic: Anyone have any success playing Driving games using a normal joystick?  (Read 1665 times)
lisowskikevin
  • Last login:April 02, 2024, 07:49:55 pm
  • If you take shortcuts, you get cut short.
Hey guys,
Do I need a thing wheel to play games like off road racing and super sprint? I tried configuring player 2 but I really don't understand it.
Just wondering if anyone has had any luck using a normal joystick versus and actual racing wheel.
LASooner
  • Last login:July 06, 2025, 08:09:32 pm
A digital joystick is no fun at all, an analog stick is better, but your best experience is going to be with a spinner, trackball or steering wheel.
  • Last login:Today at 11:18:12 am
Ugh.... why do you want to do that to yourself?  :whap
actionless
  • Last login:February 06, 2016, 03:11:49 pm
270 wheel games are very playable on Ultimarc U360 sticks but you can forget 360 wheel games.
270 wheel games are doable on normal stick but it aint fun.
  • Last login:Today at 10:39:28 am
I've never tried it, but the key would be adjusting the Digital Speed and Digital Center settings in the analog input section of MAME's in-game menu.
When you substitute a button or joystick direction for an analog control in MAME, it doesn't simply go full left or full right.
Digital Speed adjusts how fast the virtual analog control is moved from rest to limit and Digital Center adjusts how fast the virtual analog control returns to center after you release the button or move the joystick to center.
So with reasonable settings, the car would turn farther left the longer you hold the joystick left and you can bump the joystick between center and left at a certain rate to keep the car pointed where you want.  Of course you're only going to find the proper setting through trial and error and it's still not going to be as good as having real controls.
If you just want some racing games on your cab and aren't hung up on specific games, just install the ones from this spreadsheet marked "joystick" or "any"
https://docs.google.com/spreadsheets/d/1pJLy8JgRF7dL1X3CcDyDLKOLSIJs4gYZY4DLI0pmnmE/edit#gid=0
On a side note Midway Arcade Treasures 3 (PC game) doesn't support analog input for great games like Hydro Thunder.
The analog controls were ditched and the games are set up to be played with a keyboard making them play better on a standard cab.
The games each have individual .exe and can be launched via command line.  -f for fullscreen.
(EDIT: Just for clarification, the games added for MAT3 Deluxe do not support analog controls.  MAT3 Deluxe includes games from MAT1&2 which do support analog controls)
« Last Edit: May 05, 2015, 09:54:02 am by BadMouth »
lisowskikevin
Thank you for that crazy detailed response! Much appreciated.
