Author Topic: MiniPac and 9 leds  (Read 2331 times)
hycday
  • Last login:May 07, 2025, 03:53:41 pm
MiniPac and 9 leds
« on: May 03, 2015, 01:54:29 pm »
Hi,
I have a MiniPac (https://www.ultimarc.com/images/Minipac_wiring.pdf) and 9 buttons : 5 blue led ones, 4 red led ones (5 volts leds).
I would like to know if it is possible to wire all that together on a MiniPac, and if so, how to do it please ?
Here is the MiniPac. I used the wires of GROUP J4, 1 RIGHT and 1 LEFT here, to connect them to my Blue button and Red button (respectively).
If I connect the MiniPac right now, the buttons should work, but not the leds.
To connect the leds, I have this IDE Flat Data Cable which I can plug to the MiniPac on one end, and cut on the other hand to fix the insulated spade/connectors that I would connect to the buttons for the leds.
As the MiniPac has 3 "GROUND" and 3 "5VOLTS" wires, I would like to know if it would be possible to have 9 leds buttons (they are one color leds), thus 3 per wire. If so, how could I connect that ?
Can I follow that (for the leds : + on "5volts" and - on "GROUND"):
and that (for the switch, as I already did):
and have no electric risks?
Once done (if that is possible), would I be able to also connect other switches ? If so, how many (if there is a limit other that what the MiniPac offers, i.e. usb limitation).
Thank you for your help !
day
« Last Edit: May 03, 2015, 01:56:25 pm by hycday »
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: MiniPac and 9 leds
« Reply #1 on: May 07, 2015, 04:38:53 am »
Presumably you want the LEDs simply to be lit all the time?
If so, then this would work. You would be able to power them from the 5 volt pins. But there would be a maximum of around 20 LEDs.
For more than that, a convenient power source might be a hard drive power connector.
hycday
« Reply #2 on: May 07, 2015, 10:20:36 am »
Hi Andy,
Thanks for your reply.
Yes, all lit all the time (just out of curiosity, what would be the wiring if I want the LEDs to be lit only when pressed?)
so out to approx 20LEDs maximum, is it per pins ? or over the 3 ? if so, what is the limit per pin ?
Thanks again
AndyWarne
    • Ultimarc
« Reply #3 on: May 09, 2015, 01:18:29 pm »
The "fixed" 5V pins on the Mini-PAC are directly wired to 5 volts so one pin should be OK for all LEDs.
If you wanted the LED to light only when pressed:
Wire the "-" of the LED to the same I-PAC input as the switch.
Wire the "+" of the LED to the 5V pin.
hycday
« Reply #4 on: May 12, 2015, 03:39:39 pm »
Andy, Thanks a lot. This is some quality Customer Service. As always !
