Author Topic: Normal primer or mdf primer?  (Read 2878 times)
davidgilmour
  • Last login:April 11, 2025, 09:01:44 pm
« on: May 02, 2015, 11:41:13 am »
I am gonna prime my mdf cabinet. Can I use a normal regular primer?
  • Last login:November 29, 2025, 04:34:53 pm
Re: Normal primer or mdf primer?
« Reply #1 on: May 02, 2015, 01:09:11 pm »
I use regular primer, usually whatever is least expensive. I'll do a coat or two, sand, and do a final coat and then sand again. Gives a nice, smooth finish. You will have to pay close attention to any cut surfaces, as they may need filling.
davidgilmour
« Reply #2 on: May 02, 2015, 01:18:53 pm »
Thanks, will do that too.
RetroGreg
« Reply #3 on: May 08, 2015, 01:43:55 am »
Use a foam roller if you can. I always get really good results with them on mdf.
  • Online Online
  • Last login:Today at 12:24:01 pm
« Reply #4 on: May 08, 2015, 09:49:27 pm »
Ditto on the foam roller. I also tend to use name brand brushes, not the cheap ones.
