Author Topic: Win7 Super Resolution GroovyMame Newbie  (Read 6869 times)
lacanian
  • Last login:June 06, 2021, 06:59:26 am
  • Go FightCade!
    • forum.arcadecontrols.com/index.php/topic,143714.0.html
« on: April 29, 2015, 06:25:08 pm »
There are numerous posts about this I know. I've spent hours reading through them and trying to understand as much as I can with my new hobby.
Once again thanks to Cools and Calamity. Your names always come up while I research this stuff helping people like me out.
Here is the procedure I followed.
OS: Win7 Pro x64
CRT_EMU_DRIVER already installed, and VMMaker executed previously.
Sega Astro City Cab - MS9 @15kHz
- Extracted vmmaker 1.4
- edit VMMaker.ini
- add MameExe and IniPath
  - Change: ListFromXML = 0
  - Change: GenerateXML = 0
  - Change: ModeTableMethod_Custom = 0
- Rename ResList - super.txt to ReslList.txt
- edit mame.ini
  - resolution 2560x0
  - cleanstretch 2
  - monitor arcade_15
- execute VMMaker.exe as admin
- Restart Windows 7
- Screen flickers. I plug in my 31kHz monitor and it does the same thing. It was still in the middle of updating.
- I grab the LCD and run ArcadeOSD as admin.
- Lock unspported modes -> No
- Select 640x480 60i 59.889 15.601 custom
- Plug in my 15kHz monitor. The imaged is synced.
- Set as desktop mode
- Executed GroovyMame64 -> Error SwitchRes: could not find a video that meets your specs
- ArcadeOSD as admin
- Select 2560 240 60p 60.004 15.661 custom
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
Re: Win7 Super Resolution GroovyMame Newbie
« Reply #1 on: April 30, 2015, 04:52:20 am »
Are you running GroovyMAME as admin as well?
  • Last login:March 12, 2026, 04:46:23 am
« Reply #2 on: April 30, 2015, 05:41:40 am »
No, he isn't, that's indeed the problem, GM can't read the registry.
lacanian
  • Go FightCade!
« Reply #3 on: April 30, 2015, 06:17:56 am »
Thats right I wasn't running GM as admin.
Thanks I'll try it out!
« Reply #4 on: April 30, 2015, 06:22:44 am »
Also, it looks like GM is not finding your super resolutions. That's due to a monitor detection issue. In order to solve that, edit ReslList.txt and change 2560x by 1600x, then in mame.ini use "resolution 1600x0".
lacanian
  • Go FightCade!
« Reply #5 on: April 30, 2015, 07:29:21 am »
Oh I could kiss you.
So I edited relist.txt and changed all the
2560 x ...
 TO
1600 X ...
Set the resolution to 1600x0 in mame.ini
GroovyMAME is playing nicely now. No need to execute it as admin as well.
with ArcadeOSD I was in 640x480i, FightCade/FBA doesn't like the 1600x240 res in full screen "Problem setting '0x224x1647896bpp (0Hz)' display mode. I tried adding a 1600x224 resolution in vmmaker.ini but that didn't work. I just used ArcadeOSD to set my resolution to 1600x240 and it played nicely. I forgot to check if GM was still ok. I'll try that tomorrow.
I'll have to find the schematic to add the 75 ohm resistor to my cable.
Thanks for the help.
« Reply #6 on: April 30, 2015, 07:44:50 am »
Wait, you DO need to run as admin, otherwise it won't update the refresh rates properly.
If you want a genuine 224p mode for some reason, edit the Yres_min option in vmmaker.ini.
lacanian
  • Go FightCade!
« Reply #7 on: April 30, 2015, 08:13:57 am »
OK. I'll ensure I run as admin then.
Cools informed me that if I set ListFromXML = 0 then setting Yres_min doesn't make a difference. Is that right?
« Reply #8 on: April 30, 2015, 08:25:42 am »
You have separate Yres_min options for xml and custom stuff, check it.
