Author Topic: Sample support for Toaplan games  (Read 27707 times)
schmerzkaufen
Re: toaplan samples hack
« Reply #40 on: October 05, 2016, 05:53:28 am »
Sorry for skipping two releases but initially after some tests I decided to skip compiling my build after groovymame will leave alpha stage. After two releases seems to be working fine so here are two binaries based on version 178 with no nag/toaplan samples and couple of fixes imported from Arcade (old MAMEUIFX):
- 32bit https://mega.nz/#!5t0xHa4C!lpMTx5crVditLpU4ClHfV_7toNAqDnqWM-gDnzlIo_M
- 64bit https://mega.nz/#!1lkHwDiQ!AOktBf49tDSEXQLU9osf5a8FcVezRLPmFX3OYFYdEn4
Please remember - to use non nag to have to set skip_gameinfo 1
I tested exes only at windows 7 x64.
Wow, thanks haynor666 !  ;)
EDIT: by the way it's a bit OT question but is it hard to learn how to do custom builds like you do ? For instance what would be the steps if I wanted to try and port lesser known or forgotten mods like the Seibu RF samples support ? There's an old source file available, I just don't know if it requires actual MAME code knowledge or if it's reasonably accessible to the layman. Also does it typically require the author's permission even if the source is available publicly and I intend to use it for personal use ?
« Last Edit: October 05, 2016, 08:15:38 am by schmerzkaufen »
haynor666
  • retro maniac
« Reply #41 on: October 05, 2016, 08:12:15 am »
Would be nice if someone could test x64 binary under XP x64. x32 I test personally when I get back from work.
Doozer
  • Z80 ERROR
« Reply #42 on: October 05, 2016, 09:59:59 am »
Hi haynor666,
Do you plan to have a repository to maintain the toaplan samples hacks? I can prepare Linux builds if there is a demand for it.
Cheers,
haynor666
  • retro maniac
« Reply #43 on: October 05, 2016, 11:26:41 am »
Not really. Changes I made are all imported from Arcade(MAMEUIFX) and since every Arcade release has source published it does not make sense not too mention that I'm not going to build every release.
haynor666
  • retro maniac
« Reply #44 on: October 07, 2016, 03:51:15 pm »
New revision with visible areas modification for neo-geo games: [link removed]
« Last Edit: April 17, 2017, 10:17:09 am by haynor666 »
Fuzi
  • Last login:October 08, 2016, 05:34:25 pm
« Reply #45 on: October 08, 2016, 05:29:30 pm »
This is awesome! Any change of a version including the old hiscore patch? (I can never seem to get the hiscore plugin to work properly).
Play to Live, Live to Play.
haynor666
  • retro maniac
« Reply #46 on: October 09, 2016, 02:27:48 pm »
Old highscore is not needed so proabably it's gone forever. Right now I'm testing groovymame64_178 with highscore plugin.
schmerzkaufen
« Reply #47 on: November 09, 2016, 04:01:59 am »
Hi haynor666, could you please reupload the 64bit 0.171 version of your modified build ?
I've accidentally deleted it and I need it to do some performance comparison with the more recent build versions.
Thanks! ^^
keropi
  • Last login:December 28, 2022, 11:06:35 am
« Reply #48 on: November 09, 2016, 03:04:51 pm »
Is there also a 0.179/alpha3 build?
I am still working on my cab so I have not had the chance to run anything other than an old stock 0.171 version (need to work out the servosticks+ledblinky for automatic 4/8way...)
I have read that the latest 0.179 build is OK so I think I'll stay in this version and update my roms to it... unless there is another recommended haynor666-version for a win7/x64/6670 setup :)
« Last Edit: November 09, 2016, 03:13:40 pm by keropi »
haynor666
  • retro maniac
« Reply #49 on: November 09, 2016, 03:21:59 pm »
[link removed]
Right now I don't any plans for future versions.
« Last Edit: April 17, 2017, 10:16:44 am by haynor666 »
keropi
« Reply #50 on: November 09, 2016, 03:35:06 pm »
https://mega.nz/#!8k9kVb4B!UGW9bPFt7pwYafOCijYwZg9BZftLSIkTg95jkoQgN00
so 0.171 is your personal "recommendation" ? or your most recent "groovymame64_0178.016_alpha2" build?
« Last Edit: November 09, 2016, 03:37:03 pm by keropi »
haynor666
  • retro maniac
« Reply #51 on: November 09, 2016, 04:24:59 pm »
I didn't fully switch to 179, did some tests and use for couple of games right now because it would be to much work to fully switch to recent version (roms reorgnization, probably also nvram and even samples not mention snaps).
179 works very good but keep in mind that it might be a bit slower when compare to version 171 just like official mame.
keropi
« Reply #52 on: November 09, 2016, 05:43:35 pm »
Thanks for the answer, I can understand the whole migrating thing to a new version. This is why I am trying to find a solid "base" to start building upon.
I do have the 0.171 merged romset and your build above, seems like a good place to start. I am only interested in 2D games anyways and your patches seem to be a better deal.
I'll see how I go with this , thanks for the info!
schmerzkaufen
« Reply #53 on: November 09, 2016, 11:27:57 pm »
Thank you haynor666!  :)
funkycochise
  • Last login:October 22, 2019, 07:35:18 am
  • 8 bits generation
« Reply #54 on: December 28, 2016, 11:20:56 am »
Latest mame version for 2016 :
The exciting news that’s got people talking is that protected microcontrollers (MCUs) from a number of games have been read out and hooked up in MAME. This gives real, emulated sound in Toaplan’s Vimana, Fire Shark (also known as Same! Same! Same!) and Teki Paki, proper emulation of Tokio/Scramble Formation, M-chip emulation for Taito Extermination, Dr Toppel and Plump Pop, MCU emulation for Sega Altered Beast and Golden Axe, and partial sound in World Beach Volley. There’s more coming on this front, so stay tuned for upcoming releases!
So now toaplan samples hack will be useless. Correct emulation will now be on the regular build with sound.
I don't think it concerns all games of the hack, but for instance, I did a quick test with fireshark and vimana and it works well.
Can't wait for 0.181 being included in groovy build.
« Last Edit: December 28, 2016, 11:23:05 am by funkycochise »
haynor666
  • retro maniac
« Reply #55 on: December 28, 2016, 05:21:01 pm »
Almost - Ghox still does not hace sound so might have to keep old version for some time ;)
funkycochise
  • 8 bits generation
« Reply #56 on: December 29, 2016, 09:18:55 am »
yes, but they say "there's more coming" so...
haynor666
  • retro maniac
« Reply #57 on: December 30, 2016, 04:58:17 am »
Yeah, but in general not just for Toaplan games as You can see right now on their blog.
Sadly they don't have samples MCUs for Ghox at all so this might take a long time.
haynor666
  • retro maniac
« Reply #58 on: January 01, 2017, 01:08:54 pm »
Looks like samples support for Ghox is still in ARCADE32/64 so expect new version after 182 release.
haynor666
  • retro maniac
Re: Groovymame + Arcade32/64
« Reply #59 on: January 05, 2017, 12:29:01 pm »
Just for a test - groovymame64 181 with some modifications from ARCADE32/64: [link removed]
Build is for https://github.com/mamedev/mame/commit/cd282f04726faf3da8793872612bf8ef98adf601
« Last Edit: June 18, 2017, 01:39:55 pm by haynor666 »
funkycochise
  • 8 bits generation
« Reply #60 on: January 06, 2017, 01:23:34 am »
haynor666
  • retro maniac
« Reply #61 on: April 17, 2017, 10:25:21 am »
All link removed. New version will be probably when new groovymame will be published.
I'm cleaning disk from old patches but thought someone might some use of those patches (in case anyone prefer older mame versions).
Scripts from version 151 to 155 were standard mame. Starting from 156 patches were for building groovymame with patches imported from mameuifx - https://mega.nz/#!J5MGGKRL!rqhSt76-VSIBg25I0b9rByb-zAqmEjePtjD-NE7uKfw
haynor666
  • retro maniac
« Reply #62 on: May 21, 2017, 06:45:20 am »
I forgot to add cave sh3 sources derrived from other mame version from version 144 to 151. Usefull if you have problems with performance on newer mame builds.
https://mega.nz/#!J51yHCia!QGaWQiVVwha04Sg2h6Fx1TmLlGyt66S1_n8BWbhiydg
haynor666
  • retro maniac
« Reply #63 on: June 14, 2017, 05:32:36 pm »
Here is new version 186 that adds recent Bonze Adventure protection fix (by demonkatze) and some taito_f3 fixes by Dink/MameSick/demonkatze
[link removed]
« Last Edit: July 21, 2017, 01:31:17 pm by haynor666 »
m.andrade1
  • Last login:April 10, 2025, 09:05:35 am
« Reply #64 on: June 16, 2017, 09:19:24 am »
Hello haynor666
Thank you so much for your compiled 32bit version ! I have 2 cabs running onto winxp 32bit, so convert them to 64bit will be for a long future terms, maybe when the mamedev team stop doing 32bit.
Thanks a lot
Marcos
donluca
  • Last login:February 26, 2026, 08:25:38 am
« Reply #65 on: June 18, 2017, 05:55:39 pm »
https://mega.nz/#!xgd1QAhC!R5VSwQSr6nIiNMWEF0_jAK9gyprY1wrcq6p6Nb9DxnM
Out of curiosity, what are those taito_f3 fixes about?
2.- Inflatable dolls
haynor666
  • retro maniac
Re: Sample support for Toaplan games
« Reply #66 on: June 19, 2017, 02:00:37 am »
Fix for missing graphics in Greed Seeker continue screen, fix for missing text in Arabian Magic during intro.
donluca
« Reply #67 on: June 19, 2017, 04:28:39 am »
Interesting, thanks!
Recapnation
  • Last login:February 23, 2026, 12:10:18 pm
    • Eiusdemmodi
« Reply #68 on: June 19, 2017, 12:48:04 pm »
Is the Bonze Adventure "fix" a hack like the F-3 ones or is it being submitted to MAME Dev?
haynor666
  • retro maniac
« Reply #69 on: June 19, 2017, 12:59:10 pm »
Recapnation
    • Eiusdemmodi
« Reply #70 on: June 19, 2017, 01:51:02 pm »
Thanks. So is it suitable for submission? Or they just don't bother at all?
Also, does your build include other "Arcade" fixes such as the NB-1 one (Nebulas Ray and others) they mention there?
haynor666
  • retro maniac
« Reply #71 on: June 19, 2017, 02:46:37 pm »
I'll post all changes in new topic.
donluca
« Reply #72 on: June 19, 2017, 06:08:47 pm »
No. You can read whole story - http://www.1emulation.com/forums/topic/35800-arcade-0185/
Very interesting read, thanks for sharing.
So those are not fixes, but rather hacks to make things work.
This means there's something wrong underlying in MAME's emulation of the Taito F3 arcade board and the hacks are made so that despise errors in the emulation, the correct result come out.
mdd45
  • Last login:July 22, 2025, 06:03:10 pm
« Reply #73 on: July 19, 2017, 05:39:15 pm »
Please release your gm 0.187 32bit version if possible. Thanks in advance
haynor666
  • retro maniac
haynor666
  • retro maniac
« Reply #75 on: August 01, 2017, 03:12:33 am »
Sample support no longer need, all toaplan games will have in next version native sound :) Topic can be closed.
