Author Topic: LED buttons and Joysticks with the IPAC ultimate I/O  (Read 6022 times)
Mangs
  • Last login:October 10, 2016, 08:28:21 pm
« on: April 20, 2015, 11:33:34 pm »
New here so dont hesitate to correct me if im wrong on anything as any advice will be appreciated
Trying to design my first control panel as a hopeful start to my first arcade machine depending on how this goes
im currently looking at buy this kit of joysticks and buttons:
http://www.arcadeworlduk.com/products/2-Illuminated-Joysticks-And-20-Illuminated-Arcade-Buttons-Kit.html
and of course the IPAC ultimate i/o interface:
http://www.ultimarc.com/ipacuio.html
Im just wondering if the IPac will be able to power and control the 12v leds that come with the kit im looking at? or will i have to look at some different 5v leds buttons and joysticks?
Also what kind of connection would i have to use for the LEDS on the board? im assuming i can purchase something like a harness to connet the LEDs into?
Also thought id chuck up my CP design for some info:
« Last Edit: April 20, 2015, 11:36:18 pm by Mangs »
Re: LED buttons and Joysticks with the IPAC ultimate I/O
« Reply #1 on: April 21, 2015, 11:30:04 am »
Mr_Numbers
  • Last login:December 01, 2017, 10:49:05 am
  • Long time lurker, first time builder
« Reply #2 on: April 21, 2015, 11:48:53 pm »
Welcome to the forum, hope you learn alot about this great hobby.
Trust me this forum will let you know how they truly feel in a heartbeat  ;)
No offense, but these parts are sub par in most of our opinions.  If you are going to get into the hobby and build a CP I would recommend getting good gear that will last (plenty of vendors here and lots of reviews so look for yourself).
I'm kinda learning about this myself but believe you may need an external power supply for the 12v LED's (I.E. your PC).  Are you planning on swapping the LED's?  If not I don't think you would really need the I-PAC ULTIMATE I/O as it looks primarily designed for RGB LED setups.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: April 25, 2015, 03:30:40 pm »
The I-PAC Ultimate I/O will power 12V LEDs. You would need to move the positive pin on the Molex connector which plugs into a HDD power conn, so it it powered from 12 volts (yellow wire).
The board has 96 channels Our RGB LEDs are pre-wired but if using alternative controls we have connection wires in packs of 10.
Andy
Mangs
« Reply #4 on: April 27, 2015, 11:38:10 pm »
Thanks for the reply Andy,
Ive decided to go with some different buttons anyway as ive looked around and found much nicer ones http://www.paradisearcadeshop.com/buttons-il-industrias-lorenzo/809-il-psl-l-translucent-with-black-concave-plunger.html#/microswitch_force-50_gram_microswitch
Ive purchased these along with them http://www.paradisearcadeshop.com/button-leds/100-il-lumination-rgb-5vdc-led.html
with regards the LEDs im purchasing they already come with wires attached but im interested in the which connectors are used for the harnes to fit onto the pins of the IPAC?
cant seem to find the info anywhere
Thanks again for the reply
ChanceKJ
« Reply #5 on: April 28, 2015, 02:16:21 pm »
Useful Molex Part Numbers for if you want to "roll your own" interconnect. (i know i sent this to you in a reply to your PM, but if anyone else comes across your thread they will see it too!)  ;D
Molex Micro-Fit 3.0™
43645-0200 - 2 circuit Male
43640-0201 - 2 circuit Female
43025-0400 - 4 circuit Male
43020-0401 - 4 circuit Female
43025-0600 - 6 circuit Male
43020-0601 - 6 circuit Female
43025-0800 - 8 circuit Male
43020-0801 - 8 circuit Female
43030-0007 - Female pins
43031-0007 - Male pins
2.54mm Pitch SL™ Crimp Housing
22-55-2101 - 10 Circuit
22-55-2201 - 20 Circuit
22-55-2321 - 32 Circuit
16-02-1125 - SL™ Crimp terminals
