Author Topic: Daytona USA - Converting a Twin cabinet "correctly".  (Read 147385 times)
BigPanik
  • Last login:July 06, 2025, 05:57:21 pm
Re: Daytona USA - Converting a Twin cabinet "correctly".
« Reply #80 on: December 08, 2015, 04:27:45 pm »
You can find the results of my work some years ago: http://superusr.free.fr/model3.htm
SailorSat
  • Last login:December 08, 2025, 05:06:00 am
    • For Amusement Only e.V.
« Reply #81 on: December 08, 2015, 05:09:49 pm »
I spent months on troubleshooter 2 finding all the needed memory locations only to get another release of the emulator soon after, which makes the hack incompatible.
And most likely those outputs are not in RAM or RAM2 area too... I can only imagine the hustle :(
Hm... Yeah, some of that command definition seems familiar :)
around line 420
  • Last login:December 13, 2025, 11:44:57 pm
« Reply #82 on: December 09, 2015, 08:54:23 am »
Yeah... the outputs are generally easy enough to re-offset as they are in relation to RAM or RAM2 but all the mouse code I have to block is all over the place.
charliew
  • Last login:February 07, 2020, 08:31:12 pm
« Reply #83 on: February 09, 2016, 01:55:22 pm »
This is amazing!
If only Supermodel would support game linking..
Would it also be possible to interface this with a PS3, either directly or via a pad-hack to the custom board somehow?
SailorSat
« Reply #84 on: February 10, 2016, 08:49:19 am »
With a different Firmware, that should work fine with PS3 (actually most arduino gamepad examples are PS3 Pads anyway).
One might try an Logitech Wheel and the L2M2 though.
charliew
« Reply #85 on: February 10, 2016, 07:29:32 pm »
Thanks.
That sounds hard to implement though, as it would have to emulate the input of a supported ps3 wheel as well.
Too bad there is no L2M3.
Rumblebelly5
  • Last login:October 14, 2019, 10:34:50 pm
« Reply #86 on: March 18, 2016, 12:02:10 am »
I have read through this forum post twice and I just want to start by saying WOW! your talent and skill set in this is amazing SailorSat!
I recently acquired a Daytona USA driver that I want to put a pair of 32" LCDs into and convert it over to a Core i7 CPU so I can play other driving games as well, I have been going over the arduino code and have more than a few questions:
can this be split into two parts, input and output and handled by two atmega328's I was thinking about build a couple boarduino's and having them use v-usb to make calls back to the hardware.
Do I need to have my MEGA turned into an HID device? that isnt clear in the docs anywhere, from translating BigPaniks post on the other forum it would appear that it needs to be but I dont see the code for it in the sketch.
The cabinet's mate that I received was dropped off the back of a truck so I will need to rebuild the whole thing from the base up, I have already started to cleanup of the complete cab and I am wondering if I need to go about reinstalling all the wiring harness can is there a more direct way of putting this all back behind the screen?
The rest is more software related like what is usually heard from the speakers on the control panel and is it possible to isolate the sound from the program to those speakers? can I run two monitors with FFB on both wheels from one PC? can I run two sets of speakers so that each driver has their own experience on one PC? What would be a good replacement speaker setup for this kind of a cabinet with the sub in the seat for the most kick ;-)
SO many questions I know, but to start Im working on setting up the input side from my Arduino, once I can make that work I want to get the lights working, Already have the screen installed and the PC running Model2 as I cannot make the graphics work on MAME (which is better btw, mame or Model2?)
Again awesome work, hoping to do the conversion to mine too!
SailorSat
« Reply #87 on: March 18, 2016, 11:07:10 am »
that should be no problem. the boarduino should have enough I/O pins for the outputs (16 outputs to be exact)
nope, the default serial mode works too, although you will have to use a virtual gamepad driver (was using vJoy for a long time)
It just make the whole thing kinda "plug and play" :)
mhm... you can basically put the atmegas right behind the dash board and hook up the pots, buttons and stuff directly.
but if you wan't to use segas ffb board you should go with the original wiring.
the original cabinet is basically stereo:
- the dashboard speakers are tweeters
- the speakers next to the monitor are midrange
- the subwoofer... you guess it :)
you can absolutely do that. I did it with outrunners once.
however note: running a dual screen setup strongly depends on the software used.
the m2emulator cannot be run "fullscreen" on anything but the first screen (sure, there are tools like dxwnd to "fix" that issue).
also the m2emulator will run on the "default" audio device, so you'll have to switch the default device before starting the second emulator.
with outrunner that was pretty straight forward, as outrunners is basically dual mono - mame outputs player 1s stuff on the left channel, and player 2s on the right.
I'd rather use two pcs. (for most likely any racing game out there :))
for daytona I'd stick with m2emu for the time being.
the m2emu has some flaws (like running too fast - 60hz instead of 58hz) but most people won't notice.
the mame driver might mature over time, but currently is kinda unplayable. graphic glitches and a serious speed problem (game is running exactly half the speed it should run at -  most likely an irq issue)
xga
  • Last login:September 24, 2024, 09:01:04 am
« Reply #88 on: March 26, 2016, 04:37:46 am »
Hey SailorSat.  Do you think that we'll ever see the Mame devs do any more development work on the Model 2 emulation?  I'd love to be able to play the Model 2 racing games at their original 57.5Hz refresh rate with GroovyMame and I just can't see ElSemi doing any more work on his Model 2 emulator.
xga
« Reply #89 on: March 31, 2016, 11:01:18 pm »
Less than a week later since my post (above) and it appears that the Mame devs have done a bit of work on the Model2 driver with the latest release of Mame 0.172!   :applaud:  Even though it's only related to an audio bug for Daytona, hopefully this is a sign of further work to come!?!?
0.172
MAMETesters Bugs Fixed
- 06147: [Sound] (model2.c) daytona: Some songs can not be played and cause audio to halt (R. Belmont)
naoto.awai
  • Last login:August 19, 2025, 08:25:57 am
« Reply #90 on: June 20, 2016, 04:23:10 pm »
Hi everybody!
This is my first post, but I've been reading You for a while.
Sailorsat’s work is really awesome!
I read all the posts but I still have some doubts.
I have the following stuffs laying around:
1-virtua racing steering wheel and pedals
2-virtua racing driving board
3-arduino mega
4-ULN2003 Stepper Motor Driver Module
What other items do I need to build a DAYTON USA PC CONVERTER ?
Or... is it already available to buy ?
Is it available a wiring diagram to let me understand what part need to be connected ?
I hope my questions aren't silly!
Thank You in advance
SailorSat
« Reply #91 on: June 21, 2016, 10:33:37 am »
Unless you have the wiring harness to, you will need to find a wiring diagram for Virtua Racing.
The basic pinout for the MEGA can be found at:
https://github.com/SailorSat/daytona-utils/blob/master/DaytonaArduino/DaytonaArduino.ino
One thing I just noticed, the ULN2003 is not in the pinout ^^
A8 to A15 would be the ULN2003 lines - A8 and A9 are the CoinMeters, A10 START lamp, A11-A14 would be VR1-4 and A15 LEADER lamp
--- other than that ---
1. upload DaytonaArduino.ini to the MEGA
2. put the MEGA in DFU mode (there are various guides on the net)
3. run TurnIntoAJoystick.bat from the MEGA folder
4. un- and replug your MEGA and it should come up as DaytonaUSB "GamePad"
(I should really do a good howto on that xD)
naoto.awai
« Reply #92 on: June 21, 2016, 11:42:23 am »
Thank You SailorSat!
I'm a big fan of your projects.
I have 2 VR wheel + pedals that wait to be connected.
I'll post each step of the process, so It will be easier for everybody...al least to not repeat all the mistakes I'll do for sure !  ;D
Another question:
Unlike BigPanik solution, isn't there any need of  PL2303HX to USB TTL for Arduino in your DAYTON USA PC CONVERTER, right?
SailorSat
« Reply #93 on: June 22, 2016, 10:22:43 am »
This is correct. The DaytonaUSB gets fed via the built-in USB.
galaga.nz
  • Last login:February 17, 2025, 02:06:22 am
« Reply #94 on: July 16, 2016, 06:12:02 am »
hey I'm a newbie to mega 2560 when i build it.. i have and error
Arduino: 1.6.9 (Windows 7), Board: "Arduino Mini, ATmega328"
C:\Users\matthew\AppData\Local\Temp\build75df08496b3fdcc940505a15f57d05b2.tmp\sketch\Mega\usb_gamepad.c:259:18: error: 'PLLCSR' undeclared (first use in this function)
         while (!(PLLCSR & (1<<PLOCK))) ; // wait for PLL lock
C:\Users\matthew\AppData\Local\Temp\build75df08496b3fdcc940505a15f57d05b2.tmp\sketch\Mega\usb_gamepad.c:259:18: note: each undeclared identifier is reported only once for each function it appears in
Can any one help??
« Last Edit: July 16, 2016, 06:13:41 am by galaga.nz »
SailorSat
« Reply #95 on: July 17, 2016, 08:09:19 pm »
You can't use the Arduino IDE for the "mega" subdirectory, as that is a atme studio project.
The part for the Arduino IDE is one directory up.
Also in Arduino IDE select Board "Arduino Mega or Mega 2560" - It won't work with "Arduino Mini" :)
1. upload DaytonaArduino.ino to the MEGA
« Last Edit: July 20, 2016, 07:36:21 am by SailorSat »
galaga.nz
« Reply #96 on: July 20, 2016, 02:05:58 am »
hi thanks sailorsat
i opened the C:\Users\matt\Documents\daytona-utils-master\DaytonaArduino\DaytonaArduino.ion
when i up load the daytona.arduino.ion file i get the error so i cant upload it
if i open C:\Users\matt\Documents\UnoJoyModel2FFBVR\UnoJoyModel2FFBVR.ino
it will upload!!
can you tell me what version arduino ide your running
the problem is i have the "type B " so i only have gear up and down so i need to change the code to suit..
but if i cant build it i cant change it.
« Last Edit: July 20, 2016, 02:17:36 am by galaga.nz »
SailorSat
« Reply #97 on: July 20, 2016, 07:34:29 am »
what error exactly?
you can just connect D10 to ground (which will disable the decoder feature).
galaga.nz
« Reply #98 on: July 22, 2016, 04:17:12 pm »
please see error.txt
it is the log
i think is just a library  missing
thanks for all your help
SailorSat
« Reply #99 on: July 23, 2016, 08:27:06 am »
it is the log
... Don't get me wrong, but are you trying to troll?
The error log calls missing stuff in usb_gamepad.c, which is NOT part of DaytonaArduino.ino in any way.
I already told you, you cannot compile the "mega" subdirectory with Arduino IDE (and you don't have to compile it anyway)
You only need two files for the Arduino IDE:
- DaytonaArduino.ino
- DaytonaArduino.h
If you don't want to follow simple instructions, then you're on your own.
galaga.nz
« Reply #100 on: July 23, 2016, 01:41:57 pm »
i'm so sorry i feel very silly right now  :tool:
i moved the DaytonaArduino.ino, DaytonaArduino.h into their own directory and all good
very sorry for been a troll  :'(
but this is the first time i have used a arduino.
thanks you so much for all your help
Rumblebelly5
« Reply #101 on: September 10, 2016, 11:21:39 pm »
Any new updates on this? I just received my MEGA and found out that its a cheap clone that cannot be put into DFU mode :-( should have looked closer before ordering..........
sdf_
  • Last login:October 05, 2016, 06:14:08 am
« Reply #102 on: September 12, 2016, 10:40:03 am »
Hello SailorSat
I am a noob in the Daytona Cab.
I have 1 and i want to convert it.
I have done the manipulation but i don't know doing the wiring.
Do you have any photo, schema of it ?
PS: i am french, sorry for my english
Rumblebelly5
« Reply #103 on: September 12, 2016, 08:52:36 pm »
Im almost done with mine, have to trace out the wires used for the driver board then I will be done!
SailorSat
« Reply #104 on: September 13, 2016, 06:15:05 am »
http://www.arianchen.de/driveboard/ :)
There is also a wiring-diagram for the yet-to-be-completed "production board"
http://images.arianchen.de/for-amusement-only/daytona_usb/daytona-usb-teensy2-v2.jpg
Kneissl
  • Last login:March 16, 2017, 03:08:50 pm
  • Coin op love
« Reply #105 on: February 11, 2017, 12:35:59 pm »
Is the production board still in the works?
SailorSat
« Reply #106 on: February 12, 2017, 06:49:37 pm »
I haven't worked on it for some time. But I still plan to finish the layout soon :)
Priceless
  • Last login:May 29, 2019, 12:57:08 pm
« Reply #107 on: June 11, 2017, 06:42:20 am »
it is the log
- DaytonaArduino.h
Hey SailorSat, I have just completed BigPaniks M2Pac using a Daytona Drive board, he is a great guy and very helpful.
I came across your DaytonaUSB and thought I would have a try. I'm only focused on the Steering/Brake/Accelerate and FFB at this stage, is your wiring any different?
What I have done is turned the Arduino back into an Arduino.bat, uploaded your DaytonaArduino.ino, turned the Arduino back into a joystick using your files and it shows up and DaytonaUSB as a HID USB device. I can configure it in Windows as well as Model2 Emu but I can't seem to get any FFB.
Is there a certain port it needs to be on? I think I tried forcing the port to COM5 but that didn't change anything. I also made sure to have just the main USB connected as the other one is not needed for yours correct?
Any help would be much appreciated.
Thank you!
SailorSat
« Reply #108 on: June 13, 2017, 02:10:06 pm »
I don't need the additional serial port, that is correct.
The FFB is fed by my own tool - FeedbackUpdate.exe from the src directory.
Other than that.
// drive board connected on port A (digital pins 22-29)
// lamps connected on port K (analog pins 08-15)
and you'll most likely need
https://github.com/SailorSat/daytona-utils/blob/master/src/scripts/daytonas.lua
(and run daytona usa saturn ads)
Priceless
« Reply #109 on: June 13, 2017, 03:46:02 pm »
Other than that.
Yes I used FeedbackUpdate.exe and when I launch this program the lamps start working but still no FFB.
I have the driveboard connected with the digital pins 22-29
Pin 22 locates to Pin 1 on my drive board all the way to the end of 29 which is pin 8 on my drive board. This pinout is the same as BigPanik's yes? As His works with FFB for me.
I am running Daytona with Saturn ads and have installed your LUA scripts.
« Last Edit: June 13, 2017, 03:48:34 pm by Priceless »
Priceless
« Reply #110 on: June 16, 2017, 11:28:26 am »
Ok so I double checked my pinout to the Arduino DaytonaUSB file and they are correct.
I went ahead and re-installed windows, this time installing windows 7 instead of XP to see if that made any difference which it didn't :(
When I launch the feedback exe I can see the second column change numbers but the first column (I'm assuming this is for force feedback) stays at 00.
Could it be my drive board as I have a 838-11661 Drive Board with the Eprom epr-16488a (Daytona) flashed.
I am running out of ideas of what I could be doing wrong.
As I said, BigPaniks M2Dump with his Arduino Sketch works perfectly with FFB but I would LOVE to try some other games and you have made such an awesome program.
I do thank you for all your work and if anyone could help me out I would be very grateful!
Thank you so much
Priceless
« Reply #111 on: March 16, 2018, 01:10:19 pm »
Hi there,
Sorry to bump an old thread. I will make a new one if need be but I thought this was the best place to post.
I am using Sailorsats awesome tool to run Model 2 Emulator in a real Daytona Cab. I have full FFB and lamps.
I have followed all the posts and checked the source code and it has conversions for other games such as Indy500, Sega Touring Cars, Sega Rally, the it has some Super Model games (Model 3) such as Daytona 2 etc.
I have tried absolutely everything I can think of to get this working but I can't seem to get any other game with FFB working besides Sega Rally which is off and the centre isn't stable.
I am using the latest FeedbackUpdate.exe as well as all the other files.
Daytona works perfect. This is done using the Arduino which has been turned into a joystick running DaytonaUSB. It also has the LUA Script.
When I run Sega Rally the FeedbackUpdate.exe has 3 windows. The top 2 windows have the FFB data and the Lamp Data BUT with Sega Rally the bottom box has a conversion, I believe this is the on the fly translation from the Rally FFB to convert to the Daytona FFB. My Motor board is a Daytona one with the Daytona eprom.
I know Sega rally has a different eprom so the data from the emulator run through FeedbackUpdate.exe has to be converted into Daytona understandable code.
So this makes sense, Daytona only shows the top 2 windows with data, Sega Rally has all 3 windows with the bottom showing stuff like 60>50 which I believe is the on the fly translation.
Now when I run Sega Touring Cars (I have tried many roms to make sure it is the right one) I get data in the first 2 windows but nothing in the bottom.
This tells me either there is no on the fly conversion because the FeedbackUpdate tool doesn't need to convert anything as it is expecting a Sega Touring Car Motor board with Sega Touring Car eprom or I am doing something wrong.
Indy 500 Also does this, top 2 windows have data but the bottom does no on the fly conversion. I know SailorSat had many projects where she was using these games in an Indy 500 cab.
So maybe the FeedbackUpdate.exe is expecting I have a Indy 500 Motor Board and Eprom? But I have seen SailorSat running this in Daytona cabinets?
Also I can't get any SuperModel games to work at all, no data in any windows.
I have looked at the source files and I can see the calls to support all of these emulators and roms, even some mame stuff like outrun!
Has anyone got this to work with more games than Daytona and Sega Rally?
Thank you in advance!
I would be more than happy to write a detailed guide for everyone if I can work this out even with a video.
Kind Regards
« Last Edit: March 16, 2018, 07:53:12 pm by Priceless »
SailorSat
« Reply #112 on: March 17, 2018, 02:03:55 am »
The reason you don't see any conversion is that Virtua Racing, Daytona, Indy500 as well as Touring Car (and to some degree the Model3 stuff) use the same protocol and they should work with the daytona eeprom.
As for Model3 - You'll need to enable the outputs in SuperModel.
Something like "supermodel scud.zip -outputs=win" for scud race.
The FeedbackTool checks the window title for model2 though. So you might try other versions of certain games.
gareth_iowc
  • Last login:October 04, 2022, 03:27:37 am
« Reply #113 on: December 06, 2018, 05:17:47 pm »
Hi SailorSat,
Is there any more information on the spectator mode and how it's enabled?
:D
SailorSat
« Reply #114 on: December 07, 2018, 06:43:45 am »
Not yet.
I'm in the process of rewriting most of my Software based on various "hiccups" I've encountered over the years.
One such thing is the spectator not working with with less than 8 players.
gareth_iowc
« Reply #115 on: December 07, 2018, 07:21:36 am »
Well that's amazing news to hear it's still in development.
Would love to test it one day on my small home setup.
I've managed to get the control panel course select to work using the keys defined in the daytonas.lua. Just wondered if one day multipule machines could be controlled from a single control panel application?
tomsp
  • Last login:February 18, 2019, 10:52:27 am
« Reply #116 on: January 18, 2019, 03:11:03 pm »
Hi all, been busy putting together a Daytona driver using an empty cabinet, LCD and some boards from various sources - using your Arduino software SailorSat, inputs are working great, just hit a problem with the FFB:
I'm currently trying to use a 19V laptop power supply as the power for the clutch (CN8 on the driver board) but the clutch isn't responding at all. On start up the motor spins the belts, but the clutch doesn't engage.
I'm guessing the laptop supply isn't enough power, or the clutch is dead (hoping that's not the case though).
Is it 19V or a 24V supply for the clutch - I can't easily read the sticker but it looks like it says it's an Ogura OPC 20D, which is apparently 24V?
Thanks for any help :)
EDIT - does looks like it's the clutch, tried a different supply and neither 19V or 24V connected to the driver board, or even directly to the clutch have any effect.
« Last Edit: January 20, 2019, 03:27:59 pm by tomsp »
BigPanik
« Reply #117 on: January 24, 2019, 11:36:35 am »
The clutch is powered with a 19V AC not a DC PSU.
tomsp
« Reply #118 on: January 31, 2019, 04:13:06 pm »
Thanks BigPanik - sourced a 20v AC - AC transformer, but clutch doesn’t seem be gripping tightly enough. I’ve measured the voltage being passed to the clutch from the drive board during the startup sequence, it gradually works its way up to 16V, but even then the clutch doesn’t engage enough to move the wheel even slightly.
Rumblebelly5
« Reply #119 on: February 05, 2019, 12:36:14 pm »
SailorSat, how's the updates going? Just got another set of drivers that I'm about to convert would love to set up the live screens as well
« Last Edit: February 05, 2019, 11:22:36 pm by Rumblebelly5 »
