Author Topic: All games running in smaller size with GM  (Read 7603 times)
daverdfw
  • Last login:June 03, 2015, 03:04:59 pm
« on: April 17, 2015, 01:03:16 am »
when using GM, my games are smaller than they are when using regular MAME, i am using an arcade monitor , i have made the edits to mame.ini to reflect that. but still doesnt seem to work correctly. Any ideas? Thanks!
Sledge
  • Last login:August 02, 2025, 01:37:53 am
Re: All games running in smaller size with GM
« Reply #1 on: April 17, 2015, 07:37:41 am »
Give us some info to work on at least....
PC specs?
Attach your mame.ini and a log file for a game ...minimum
daverdfw
« Reply #2 on: April 17, 2015, 12:57:27 pm »
here are the logs and ini
« Last Edit: April 17, 2015, 01:00:22 pm by daverdfw »
  • Online Online
  • Last login:Today at 07:44:54 am
« Reply #3 on: April 17, 2015, 01:10:15 pm »
Your setup looks fine. What do you mean with "smaller"?
daverdfw
« Reply #4 on: April 17, 2015, 01:16:47 pm »
when I run it with regular MAME, it will fill the entire screen, with GM it is centered and smaller ill take
daverdfw
« Reply #5 on: April 17, 2015, 01:23:17 pm »
daverdfw
« Reply #6 on: April 17, 2015, 01:23:59 pm »
and to clarify, I am using a ATI X1050 with a WG4900 arcade monitor.
  • Online Online
« Reply #7 on: April 17, 2015, 01:34:53 pm »
Is that WG a multisync one? Does it have memory for adjustments?
daverdfw
« Reply #8 on: April 17, 2015, 01:35:53 pm »
I dont think? its the 19K4901
  • Online Online
« Reply #9 on: April 17, 2015, 01:40:27 pm »
This log you posted, did you really get to the point shown in your second picture or you exited before? (sorry to ask so many questions)
daverdfw
« Reply #10 on: April 17, 2015, 01:41:20 pm »
This log you posted, did you really got to the point shown in your second picture or you exited before? (sorry to ask so many questions)
i thought so, let me run it again and get into the game itself.
daverdfw
« Reply #11 on: April 17, 2015, 01:45:23 pm »
here is newer log with me playing the game for a few seconds
  • Online Online
« Reply #12 on: April 17, 2015, 01:51:12 pm »
Ok that's fine.
There's something odd. Your first picture shows a proper bounding box (leave apart the bad centering on the top). However the game itself is contained in a smaller box for some reason. Clear the ./cfg folder, maybe there's a cfg file messing with our settings.
daverdfw
« Reply #13 on: April 17, 2015, 01:52:24 pm »
Ok that's fine.
ok let me try that, the top of the monitor is a CRT issue I am troubleshooting, probably a transistor.
daverdfw
« Reply #14 on: April 17, 2015, 01:53:40 pm »
deleted all of the files in ./cfg same issue.
  • Online Online
« Reply #15 on: April 17, 2015, 01:58:29 pm »
Have you tried with -video ddraw? Do you have artwork in its folder?
daverdfw
« Reply #16 on: April 17, 2015, 02:01:39 pm »
just a black screen
  • Online Online
« Reply #17 on: April 17, 2015, 02:07:01 pm »
Have you tried those modes (e.g. 400x288) in Arcade OSD? Do they work at all?  Can you confirm there's actually a mode switch when launching games and they're not just running at the desktop's res?
daverdfw
« Reply #18 on: April 17, 2015, 02:11:00 pm »
let me try that and report back, I am off to pick up some transistors to hopefully fix the monitor. thank you for your help!
daverdfw
« Reply #19 on: April 17, 2015, 09:23:50 pm »
it works in the correct resolution, not sure whats going on, regular mame.exe fills the screen entirely.
  • Online Online
« Reply #20 on: April 18, 2015, 07:52:29 am »
Regular MAME might be just using the desktop resolution, can you confirm that?
daverdfw
« Reply #21 on: April 18, 2015, 12:16:35 pm »
how could I confirm that? Sorry new to messing with this kinda stuff on MAME specifically,
my desktop runs at 800x600 if i try any other resolution with OSD it makes things huge and wont fit in the screen.
daverdfw
« Reply #22 on: April 18, 2015, 02:09:42 pm »
I figured it out! the default.cfg files from groovymame were not copied into c:\mame\cfg
did that and it works, having some weird sound glitches now, going to build a new box with Win 7 and move off XP.
  • Online Online
« Reply #23 on: April 18, 2015, 02:30:26 pm »
That's good! Enable multithreading, that should fix your sound glitches.
I'd settle down with XP until you gain some experience, W7 is a little bit trickier to set up and there are no Emudrivers for that card anyway.
daverdfw
« Reply #24 on: April 18, 2015, 09:40:41 pm »
well I wanna use this other PC because the memory in my XP box is only 1GB, I am going to probably get a HD5450 since that car is supported in win7
Well after reading that the HD5xxx wont work, I am loading winXP64 so I can use some more RAM than on my old box.
« Last Edit: April 19, 2015, 01:59:27 pm by daverdfw »
daverdfw
« Reply #25 on: April 19, 2015, 09:52:14 pm »
one final thing, I am using GM and now with my new PC setup, the desktop is fine, in 640x480 but when switchres kicks in my vertical scroll starts going slowly, only way to fix it mess with the pot in the back of the monitor, how do I fix this in software?
big10p
  • Mmmm, arcade classics!
« Reply #26 on: April 20, 2015, 10:39:37 am »
After adjusting the pot, does the picture start rolling again when you go back to the 640x480 desktop?
daverdfw
« Reply #27 on: April 20, 2015, 11:49:36 am »
yup! thats exactly what happens.
big10p
« Reply #28 on: April 20, 2015, 07:24:53 pm »
Just had a look at the mame.ini you posted and you have "switchres 0" set in it. Not sure if this is related to your issue, though.
daverdfw
« Reply #29 on: April 20, 2015, 09:11:15 pm »
that was my old config, this new one just has the arcade_15 profile, and thats it.
big10p
« Reply #30 on: April 21, 2015, 09:50:15 am »
Maybe the vert sync pot needs cleaning/replacing?
I'm struggling to rectify interlace and interference problems with my monitor. Starting to think using a CRT is too much hassle...  :(
daverdfw
« Reply #31 on: April 21, 2015, 12:46:21 pm »
issue with mine, is that with regular MAME, it works fine.
  • Online Online
« Reply #32 on: April 21, 2015, 01:13:23 pm »
Usually with an arcade monitor you can find an adjustment for the v-freq pot that covers a wide enough range of frequencies, something like from 50 to 60 Hz, even more. If this is not the case, you could find the actual width of the range that yours allows. But it sounds like something odd is going on there. It actually sounds like a sync issue, as if your monitor is expecting composite sync or there's a problem with the wiring of the sync signals.
Maybe regular MAME stays at 60 Hz all the time?  :)
daverdfw
« Reply #33 on: April 21, 2015, 01:14:49 pm »
on the cable I have going from the CRT to the VGA the 2 sync lines are tied together, and theCRT can only do 15hz
  • Online Online
« Reply #34 on: April 21, 2015, 01:17:31 pm »
We wouldn't be using CRTs if the alternative didn't suck.  :)
  • Online Online
« Reply #35 on: April 21, 2015, 01:25:26 pm »
You mean 15kHz, for horizontal refresh. Instead, I'm talking about vertical refresh which is measured in Hz.
If your monitor is expecting composite sync you shouldn't just tie the H and V sync lines together. That's quite probably the issue. It might work for some monitors however but not for all.
What's probably happening is that your monitor is actually out of sync all the time, it's just that you're able to stabilize the picture by fine tuning the v-freq pot, but that doesn't mean it's solid so any deviation from that sweet spot makes the picture start rolling. When the vertical sync works fine, the monitor actually hangs on to the incoming signal without problems.
big10p
« Reply #36 on: April 21, 2015, 01:25:59 pm »
True  :laugh:
daverdfw
« Reply #37 on: April 21, 2015, 01:30:02 pm »
I am using the cable from here
http://www.ultimarc.com/store/section.php?xSec=11
  • Online Online
« Reply #38 on: April 21, 2015, 01:52:00 pm »
http://forums.arcade-museum.com/showthread.php?t=182282
It looks like that monitor may work with separate sync too. Anyway, I think the issue is we're outputting the wrong polarity (either positive or negative) for the expected composite  input.
daverdfw
« Reply #39 on: April 21, 2015, 02:01:48 pm »
I seperated them and now it works fine!
Now I just need my 2 vertical output transistors to hopefully fix the issue where I have like a 2" offset at the top of the screen, thanks!
