Author Topic: mame multiplemouse: 2 spinners and 1 trackball  (Read 2926 times)
limner
  • Last login:June 08, 2015, 06:59:42 pm
« on: April 14, 2015, 08:05:55 am »
Hi
i was configuring mame (ver 155) using mala (no mame gui - Windows XP) and i was trying to configure 2 spinners and 1 trackball.
all the spinners and trackball works under windows with no problems.
What i want to achieve is to have separate commands: mouse1 on spinner1, mouse2 on trackball and mouse3 on spinner2.
Enablying multimouse on mame.ini i was able to have mouse2 on spinner1 and trackball and mouse3 on spinner2.
How can i separate spinner1 and trackball in order to have separate inputs?
thanks
DarthMarino
  • Last login:September 06, 2025, 02:38:47 pm
Re: mame multiplemouse: 2 spinners and 1 trackball
« Reply #1 on: April 14, 2015, 09:16:58 am »
Are Spinner 1 and the Trackball sharing the same board?
limner
« Reply #2 on: April 14, 2015, 09:33:00 am »
the two spinners and one trackball are on the same board (optipack from ultimarc) and that board is connect using usb cable
limner
« Reply #3 on: April 14, 2015, 09:48:32 am »
mmmh, examinating the board, i have spin1 and trackball on P1 side, while spinner2 is on P2 side
so maybe this is the problem, only max two mouse on one usb port?
is it possibile?
limner
« Reply #5 on: April 14, 2015, 04:55:47 pm »
i was able to solve, but it was hard :-)
first it is important to enable multiplemouse on mame.ini
after this, using the opti-pac you must know that you can be recognized as two mouses
use one mouse as trackball (x and y axis)
use the second mouse as: X axis for P1 Spinner and Y axis reversed as P2 Spinner
i just needed to reverse the wires ;-)
P.S.
it is a controller/hardware problem, not software problem.
