Author Topic: LED Push button Advice  (Read 1454 times)
lacanian
  • Last login:June 06, 2021, 06:59:26 am
  • Go FightCade!
    • forum.arcadecontrols.com/index.php/topic,143714.0.html
« on: April 10, 2015, 10:44:04 pm »
Hi, before I make a purchase I thought I would check with the experts.
I have Seimitsu PS-14-KN push buttons and a PacLED64 (will use LED Blinky).
From my research I the best option is to purchase the Uilia S Flash LED from Paradise Arcade.
- Are there any other LED's that I should look at?
- Will the "S Flash" be useless with the PacLED64?
- Are there any LED's for Seimitsu PS-14-DN-K (24mm buttons)
Thanks.
keilmillerjr
  • Web Developer.
Re: LED Push button Advice
« Reply #1 on: April 10, 2015, 11:20:47 pm »
I got the pele rings. Pros are that they are universal and have connections for with or without use of the built in resistors. Cons are that they are brittle and will require a tiny bit of extra space around your buttons.
Not saying that pele is a better option. Just another option to consider from the same vendor that will also work with the seimitsu buttons.
lacanian
  • Go FightCade!
« Reply #2 on: April 11, 2015, 02:14:25 am »
@keilmillerjr Thanks for the reply.
Can you explain in more detail about the extra space around the buttons. Thanks.
I sent Paradise Arcade an email for their advise as well.
