Author Topic: Buck hunter shooters challenge Jamma pcb buttons not Working (Solved)  (Read 7157 times)
Spitfire
  • Last login:August 05, 2023, 07:55:31 am
Here is my dilemma. I have a perfectly working buck hunter shooters challenge pcb working in one of my jamma arcade machines. I then moved it to a different arcade jamma machine with a better quality screen. In this new machine the game and sound works as normal however I can't get any buttons to work, Start, test, volume up down as these are the only buttons on this machine. I tested a golden tee fore pcb on this cabinet and the buttons work fine for that game but not for buck hunter. I put buck hunter back in the original cab and the buttons work fine there. The jamma harness configuration in both cabs are fairly similar. The only difference I can see between the 2 cabs are the working cab has a switching power supply connected to the jamma harness with a -5volts also present. Where the non working cab has no switching power supply and no -5volt cable. The buck hunter pcb runs and gets its power from a stand alone atx power supply and is a green IT pcb board.
Any help to get it working in the new cab would be greatly appreciated. Thx in advance Joe
« Last Edit: April 11, 2015, 03:50:46 am by Spitfire »
Re: Buck hunter shooters challenge Jamma pcb buttons not Working
« Reply #1 on: April 07, 2015, 08:49:19 am »
in the original cab, follow the wires from the buttons back and see where they lead to. Make sure the buttons on the new cab lead to the same place.
Spitfire
« Reply #2 on: April 07, 2015, 09:11:42 am »
Yep exact same place pin 17 on jamma.
« Reply #3 on: April 07, 2015, 10:11:15 am »
and if you put golden tee in the buck cab, the buttons work?
to me, it sounds like a ground issue, any way to run a ground from the jamma edge to the ground side of a button?
Brian74
  • Last login:April 21, 2025, 11:11:53 am
  • Yep... I built that!!
« Reply #4 on: April 07, 2015, 11:22:08 am »
Bad edge on the jamma?
Spitfire
« Reply #5 on: April 07, 2015, 06:02:27 pm »
Hi Brian thx for the help. If it's a bad edge on the Jamma why do the buttons work for the GT pcb on the same jamma harness? If it's a bad BBH board why does it work fine in the original cab. Has me stumped?  I have tested continuity on all wires from jamma  harness to button edge and all good.
grantspain
« Reply #6 on: April 08, 2015, 07:49:43 pm »
it's a switch common problem-link pin 1 to one of your switch commons,that will prove it
Spitfire
« Reply #7 on: April 09, 2015, 02:22:57 am »
Hi grantspain thx for ur help. Sorry for my ignorance but what do u need me to do? As it has me stumped!!
« Last Edit: April 09, 2015, 02:59:09 am by Spitfire »
« Reply #8 on: April 09, 2015, 03:35:59 pm »
he's saying check the ground to the first switch
grantspain
« Reply #9 on: April 09, 2015, 07:14:54 pm »
what i mean is connect a wire to pin 1 of the jamma connector and then take the other end up to a switch and connect to the common-then try it
it take 2 mins and will prove whether it is an issue with the common wiring
Spitfire
« Reply #10 on: April 10, 2015, 05:54:53 am »
Hi mate I have check continuity to all grounds on side of jamma pin to button and from power plugs on board to jamma and to button etc and all are good. I have attached other wires from both the ground on jamma and start button pin to the button and still nothing. Checked all voltages and they are all perfect. Just as me stumped. As said GT 2005 similar green pcb board works fine. And also this board works fine in different jamma cab. Did test on a third Jamma cab and buttons didn't work on that either. Very very strange.
grantspain
« Reply #11 on: April 10, 2015, 07:34:15 am »
photo of your edge connector please
Spitfire
« Reply #12 on: April 10, 2015, 08:00:51 am »
Are these good enough?
Spitfire
« Reply #13 on: April 10, 2015, 10:24:07 am »
 Another update. I got a hold of the manual and was able to go into a diagnostics test on power up by holding down the start button. Once there I could test all the buttons and everyone registered as normal on this test. After proceeding through these tests with all working great. The board resets and loads the game. Once in the game none of the buttons function again ha ha ha it's cursed!! Any ideas???
grantspain
« Reply #14 on: April 10, 2015, 10:56:14 am »
must be something really daft going on,do the coin switches work?
Spitfire
« Reply #15 on: April 10, 2015, 06:59:07 pm »
Yep the coins mech works and registers also in the start up diagnostics. All buttons do. But once the game is fully
Loaded they don't?? As me beat ha ha
BobA
  • What Me Worry?
« Reply #16 on: April 10, 2015, 10:18:38 pm »
You have checked all the grounds.   Is the 5V good at the Jamma connector when the buck hunter board is plugged in?
ed12
« Reply #17 on: April 10, 2015, 11:37:11 pm »
just a q
on the green board from red
is u6 populated ?
if so is it on the green board?
red>
  Hardware overview:
        * NEC VR4310 CPU (similar to the N64's VR4300)
        * NEC VR4373 "Nile 3" system controller / PCI bridge
        * 3DFX Voodoo Banshee video
        * Creative/Ensoniq AudioPCI ES1373 audio
        * Atmel 90S2313 AVR-based microcontroller for protection
        * STM48T02 NVRAM
        * Conexant CX88168 modem<
green 1 @ 2
>u can tell the difference once u use the jamma interface +5/+12 will not come through
the jamma interface >(gen2)<
*Gen3 green board also has u6 populated along with x6 and r208.<
ed
Spitfire
« Reply #18 on: April 11, 2015, 03:49:59 am »
So I received an email from a tech at IT he said that because I am connecting my monitor directly through the graphics card and not through the jamma this is the problem as the pcb requires signals from the card to operate correctly. I connected a y VGA splitter so the signal went through the pcb also and all is working perfectly. Thanks everyone for your efforts. Hopefully this will help others in the future. Thx Joe
Re: Buck hunter shooters challenge Jamma pcb buttons not Working (Solved)
« Reply #19 on: April 11, 2015, 09:10:42 am »
thanks for posting the fix in the thread, more people need to do that and not just post "fixed it!"
JimmyU
  • Last login:July 28, 2025, 08:19:07 pm
  • I believe I can fly!
« Reply #20 on: April 11, 2015, 11:17:21 am »
Wow, that's a pretty random fix. Good thing you emailed IT; I don't think you would have ever figured that out on your own.
