Author Topic: Vewlix-L Sound Issue with amp  (Read 1749 times)
lacanian
  • Last login:June 06, 2021, 06:59:26 am
  • Go FightCade!
    • forum.arcadecontrols.com/index.php/topic,143714.0.html
« on: April 05, 2015, 06:32:58 am »
Today I started preparing a Vewlix-L cabinet to connect up to a PC.
I want to connect the speakers directly to an amp however every connection results in the right speakers kind of clicking. I'm assuming this mat have something to do with how the 4 speakers are connected.
My first test was this setup. I assumed Orange is positive and green is negative.
I get sound through both speakers but they just keep clicking.
« Last Edit: April 07, 2015, 07:27:27 am by lacanian »
lacanian
  • Go FightCade!
Re: Velix-L Sound Issue with amp
« Reply #1 on: April 05, 2015, 06:43:26 am »
So onto plan B. I connected the Vewlix Speaker wire up.
On my JAMMA fingerboard I soldered the speaker connections. Plugged into the right speaker of the AMP and the looped the L and R channels to the left speaker. I had to connect it this way to get the speakers working.
lacanian
  • Go FightCade!
« Reply #2 on: April 05, 2015, 06:45:49 am »
How do I connect the speakers directly to the AMP? I can't get behind the cabinet to where the speakers are to know exactly what's happening to the wires.
Please no posts mentioning a JVS-PAC. As you can see the setup is working in plan B the same way the JVS-PAC would be functioning.
lacanian
  • Go FightCade!
« Reply #3 on: April 07, 2015, 07:26:56 am »
I'm sure there is something satisfying in solving your own problem, but when you took the long road to solve it "I don't get no satisfaction!"
I took the Vewlix-L cabinet apart to get to the speakers. Check the polarity of the speakers and ensure everything was wired correctly. Well it was.
I plugged in my Yamaha AV amp and everything worked perfectly. My cheap amp was causing the speakers to pop. There rated at 300w so I have no idea why they do this. Perhaps because it's a 2.1 amp. I have no idea.
