Author Topic: VerticalAspect and Super Resolutions  (Read 1718 times)
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
« on: April 03, 2015, 10:26:55 am »
Hi
I can't seem to get the VertcalAspect setting in VMMaker.ini to work. No matter what I set it to, the vertical games still display at 4:3 ratio in groovyMAME. Does this setting not work with Super Resolutions?
I've also tried toggling the keepaspect setting in mame.ini but no joy. Is there another setting I need to change?
Thanks.
Calamity
  • Moderator
  • Last login:Today at 02:59:06 am
  • Quote me with care
Re: VerticalAspect and Super Resolutions
« Reply #1 on: April 05, 2015, 01:50:43 pm »
The "vertical aspect" option in vmmaker.ini is only meant for the normal resolution. If you're using super resolutions then just enter a custom aspect ratio for the -aspect option in mame.ini (or better, create an *empty* text file named "vertical.ini" and add the desired aspect option inside).
Steps to create a log:
big10p
« Reply #2 on: April 06, 2015, 06:22:08 am »
OK. Thanks.
