Author Topic: Changing battery power to be USB power on small LED device  (Read 1381 times)
markronz
  • Game on!
« on: April 02, 2015, 01:15:29 pm »
Hey everyone.  Just hoping someone might be able to lend me a little electrical knowledge.  I have this small device.  All it is, is when a switch is pushed it turns on a small LED light on the top.  Currently, it's battery powered by 3 AAA batteries.   I'd like to make it so that this thing is attached to USB to be powered instead.
Here are some pictures of the device.  Top View:
Switch:
Lit Up:
Bottom Batteries:
My real question is, is it as simple as chopping those two wires going to the battery bank and splice those over to a USB cable instead?  Anything I am missing?   I need to figure out what wires to use inside a USB too...
Thanks for any help!
markronz
  • Game on!
Re: Changing battery power to be USB power on small LED device
« Reply #1 on: April 02, 2015, 02:04:13 pm »
Someone directed me to this url. Should be very helpful!
http://www.instructables.com/id/How-to-power-nearly-anything-off-a-USB-port/#step3
I think I'm just going to try it out.   Worst case scenario, I just have to replace the LED!
RamjetR
  • Last login:July 04, 2021, 03:27:58 am
    • My Youtube Channel
« Reply #2 on: April 02, 2015, 08:25:56 pm »
The quick answer is just chop the USB lead and connect the 5V and GND to the + and - of the battery contacts. The reason is simply that 3x1.5V is 4.5V and the additional half a volt will make at most 3-5mA difference to the LED. You won't even see a difference to the brightness. You'll be fine.
Gentlemen.... Start your engines!
My Youtube Channel http://www.youtube.com/user/ramjetr?feature=mhee
Try my RamjetM2Borderless V0.7 utility for your M2Emulator shooting games here https://docs.google.com/open?id=0B-P3wlCiYEm3RzhCZk1NcFR3blE
Try my Sega Model 2 Output Utility RamjetVR V1.4 https://docs.google.com/file/d/0B-P3wlCiYEm3VHhBMXNxZGVIQk0/edit
danny_galaga
  • Last login:Today at 07:26:04 am
    • dans cocktail lounge
« Reply #3 on: April 03, 2015, 04:28:12 am »
 :stupid
