Author Topic: Whats the best way to get the shape of Logitech g25 for cutting out dash?  (Read 3773 times)
Boomslang
Ive seen a few get near perfect cutouts or used mdf/ply and was wondering how you get the shape of the wheel for making such a cutout
vandale
  • Id 10 and t error
I prefer to create an adapter and mount the base inside the cabinet and connect it to the back of the shaft from the arcade wheel, then relocate the buttons. Doing a dash cut and fit usually looks poo in my opinion. If you have some good examples then flick them up as I haven't seen any
Cheers
Boomslang
yes while I agree it looks better it is too much work for what im after. I had a brief look but this one was pretty nifty looking I thought. Im definitely not going down the route on making a longer shaft etc
http://forum.arcadecontrols.com/index.php/topic,131911.0.html
  • Last login:January 01, 2026, 05:29:50 am
get some cheap foam board
cut out the rough shape, then start cutting out smaller pieces until you get it to where you have less than a quarter inch gap
hold the foam board against the wheel
use a pencil to trace around the wheel housing which will mark all the high spots
trim the high spots
repeat until perfect
use foamboard as template to trace the outline onto wood
pretty much this
http://www.familyhandyman.com/tools/how-to-scribe-for-a-perfect-fit/view-all
or
get the mdf dashboard close, but oversized
tightly wrap the wheel in plastic
slap bondo in the gaps
sand, sand, sand
Generic Eric
Measure 360 times, cut once.
SegaOutrun
  • Last login:March 28, 2019, 03:02:05 am
  • Brakes are overrated
I used birchwood and an exacto knife back when i have my huge MOMO wheel. Its a very thin wood that make it easy to get a clean cut.
Sadly this is the best picture i could find so it was long ago. You can see the outline of the birchwood under the vinyl. I have since upgrade by extending the shaft of my new wheel and hiding the body
« Last Edit: April 04, 2015, 03:30:50 pm by SegaOutrun »
RamjetR
  • Last login:July 04, 2021, 03:27:58 am
    • My Youtube Channel
I covered my wheel with cling wrap, then paper machete the base to form a 3D shape. Then when its dry and hardened. I trimmed it with scissors to the right depth I needed. Then placed the model onto the plastic dash panel I was cutting and with a marker pen drew the inside template shape. cut the hole and it was pretty close to spot on.
Gentlemen.... Start your engines!
My Youtube Channel http://www.youtube.com/user/ramjetr?feature=mhee
Try my RamjetM2Borderless V0.7 utility for your M2Emulator shooting games here https://docs.google.com/open?id=0B-P3wlCiYEm3RzhCZk1NcFR3blE
Try my Sega Model 2 Output Utility RamjetVR V1.4 https://docs.google.com/file/d/0B-P3wlCiYEm3VHhBMXNxZGVIQk0/edit
Fursphere
  • Last login:Yesterday at 12:34:51 am
One of these things helps...
http://www.amazon.com/General-Tools-6-Inch-Contour-Duplication/dp/B00004T7RA
Had no idea what those were called or how cheap they were.
I'll definitely be ordering a little larger one.
Fursphere
Took some creative googling to find it, because I couldn't remember what they were called either.   :P
Generic Eric
I think they are in the same aisle as the levels, squares and tape measures at Menards.
