Author Topic: Interface for Analog gas pedal  (Read 2252 times)
sroberts
  • Last login:November 07, 2023, 09:51:53 pm
  • Will my game cabinet ever be finished??
« on: March 30, 2015, 10:51:34 pm »
I have a 1kΩ analog pedal from a Spy Hunter cabinet that I'm looking to interface to sdlmame running on arch linux.  I read about u-hid, a-pac, aki, and some other options.   Much of the recent chatter seems to be about u-hid - is it a current solid solution or is a-pac still the one?  I gather I may need to change the pot, that's not a problem.
Thanks,
Steve
  • Last login:Today at 09:01:41 pm
Re: Interface for Analog gas pedal
« Reply #1 on: March 30, 2015, 11:35:44 pm »
Is the AKI from B-Spec Labs still sold anwhere? (if it's still available, I'll add it to the wiki.)
An Analog Encoder like U-HID, U-HID Nano, or KADESTICK should work fine with any potentiometer -- the U-HID software has several adjustments that the KADESTICK currently doesn't.
You don't need to replace the pot unless it causes jumpy/jittery output.
