Author Topic: Ok....now the heck do I power this Power Supply Box???  (Read 1175 times)
lisowskikevin
  • Last login:April 02, 2024, 07:49:55 pm
  • If you take shortcuts, you get cut short.
« on: March 24, 2015, 04:02:39 pm »
Hey Guys,
I have this Switching Power Supply I ordered from GGG but there is no power cord that came with it. How the heck do I power this thing? There is no slot for a plug either!
« Last Edit: March 24, 2015, 04:05:13 pm by lisowskikevin »
behrmr
Re: Ok....now the heck do I power this Power Supply Box???
« Reply #1 on: March 24, 2015, 04:14:32 pm »
The bottom three get wired to AC house current/mains.
http://lmgtfy.com/?q=how+to+wire+an+arcade+switcher+power+supply
« Last Edit: March 24, 2015, 04:16:40 pm by behrmr »
lisowskikevin
« Reply #2 on: March 24, 2015, 04:17:32 pm »
SO i guess I need to take a PC power cord....cut off the end then splice the 3 wires into the bottom 3 slots of the pictured power supply?
If so which cable goes into which? ie- what is the difference between AC1 and 2 and that symbol thingy?
« Reply #3 on: March 24, 2015, 04:20:14 pm »
  • Last login:November 26, 2025, 03:26:23 pm
« Reply #4 on: March 24, 2015, 04:25:46 pm »
yes
the symbol thingie is what's known as "ground" and gets wired to the green lead inside your cord.
AC1 and AC2 are the white/black wires (alternatively brown and blue depending on where your cord was made) normally the very bottom most lead is the "hot" wire (black or brown) and the next one up is "neutral" (white/blue)
this will result in a power supply that is powered all the while the cord is plugged into the outlet. if you need to switch it off and on, you are going to need to supply some kind of toggle switch.
lisowskikevin
« Reply #5 on: March 24, 2015, 04:32:15 pm »
The search function works here.
http://forum.arcadecontrols.com/index.php?topic=3702.0
Thanks, I should have tried that first.
My apologies gents.
behrmr
« Reply #6 on: March 24, 2015, 08:06:12 pm »
Also another good source of information http://therealbobroberts.net/acwiring.html
