Author Topic: ATOM-15: Works, but boot is still distorted?  (Read 4939 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
« on: March 20, 2015, 10:49:28 pm »
I have an ATI 4890 connected to a Crescendo TC1600 transcoder connected to a regular CRT TV.
I've used ATOM-15 to create a modified BIOS, and the BIOS flashes fine, but the Windows 7 boot process is still very distorted.  I think I can see a diagonal retrace and the screen flickers extremely bad.
Is it possible that my card is not compatible, or that I need modified 15.7 kHz settings?
zebidia
  • Last login:February 04, 2016, 06:53:29 pm
Re: ATOM-15: Works, but boot is still distorted?
« Reply #1 on: March 21, 2015, 09:12:27 pm »
I also have trouble with Atom-15 with my TV. The bios for my 4650 modified and flashed fine, but I get vertical roll on the TV at boot. Once Windows 7 takes over, all is good.
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
« Reply #2 on: March 22, 2015, 09:19:08 am »
You might just need to adjust the vertical sync on the TV slightly.
  • Last login:Today at 05:28:27 pm
« Reply #3 on: March 24, 2015, 07:45:21 am »
The 15 kHz settings applied by ATOM-15 are quite standard. I'm assuming you only checked the 15 kHz box. What output are you using? Have you tried the other one?
sofakng
« Reply #4 on: March 24, 2015, 08:12:04 am »
Yeah, my card has 2x DVI and 1x S-VIDEO outputs (it's an ATI 4890 PCIe card).  I'm using a DVI-to-VGA adapter (passive) which then connects to the Crescendo TC1600 and finally outputs component video to the TV.
I've tried both DVI outputs with ATOM-15 and both produce the same result. :(
Also, you are correct that I only checked the 15 kHz checkbox (and I double-checked and reflashed the BIOS, etc, just to make sure)
« Reply #5 on: March 24, 2015, 08:21:13 am »
It'd be good to test with another monitor to discard a problem with the video card/atom-15. It could be just that the timings generated by ATOM-15 are not accepted by either the transcoder or the TV. Maybe the transcoder is not able to produce a working composite sync signal out of the separate sync signals. I remind I had to force all bios sync polarities to negative otherwise it wouldn't work on some arcade monitors.
sofakng
« Reply #6 on: March 24, 2015, 08:32:09 am »
Unfortunately, I literally don't have any other CRTs in the house.
Could I use ArcadeOSD to test the resolution/signal that ATOM-15 is sending?
« Reply #7 on: March 24, 2015, 08:37:08 am »
No, that's not possible.
Also, I'm assuming the Windows 7 boot screen you're seeing is the old Vista style boot screen that gets activated automatically when the bios is flashed, not the usual Windows 7 boot screen, isn't it?
sofakng
« Reply #8 on: March 24, 2015, 08:46:38 am »
« Reply #10 on: March 24, 2015, 08:51:12 am »
Anyway a picture/video might help.
