Author Topic: Rockola tone arm adjustment  (Read 5482 times)
Cadcrew
  • Last login:March 30, 2015, 06:19:42 pm
« on: March 20, 2015, 06:09:42 pm »
This is my first post, so any help would be much appreciated.
I have a rockola 453 jukebox.
The tone arm misses the beginning of the record and starts about 10 seconds in.
I have adjusted the screw yet it makes no difference I can not get it to play the beginning of the track.
Thanks in advance
Doghouse Riley
  • Last login:February 24, 2023, 05:16:10 am
Re: Rockola tone arm adjustment
« Reply #1 on: March 21, 2015, 08:15:26 pm »
The "screw" just secures the arm in position,
Slacken it off.
Start the jukebox and wait until the arm  is about to "set down" on the record.
Then stop it with the scan switch.
Move the arm carefully until the stylus is at least 1/16" in from the edge of the record.
Then tighten the screw.
At the same time it would be as well to check that the gripper arm at the "rest" position is exactly between the first and last records. A common fault is that the gripper arm is slightly nearer one or the other. This can mean records get scraped against the duckbills as they are removed and replaced. The adjustment is quite simple and is explained in the manual.
« Last Edit: March 22, 2015, 03:41:23 pm by Doghouse Riley »
I don't mind if you don't like my manners.
I don't like them myself, they're pretty bad!
I grieve over them on long winter evenings.
Cadcrew
« Reply #2 on: March 30, 2015, 05:57:24 pm »
Thanks for replying. But tried that and still won't start at beginning of record. Still missing the first 10 to 15 seconds of each song.  Also when I put the b side on the a side plays first followed by the b side. I have cleaned the a b snap switch but still doing it. Thanks in advance.
Doghouse Riley
« Reply #3 on: March 31, 2015, 04:00:56 pm »
Try as I suggested again and stop the arm, just as it is about to set down.
How much lateral play is there in the arm?
If there's more than a little, this might be the cause of the problem.
Another thing to check is whether the turntable is completely horizontal. Use a small spirit level on it to check.
If the jukebox is leaning even slightly towards the back, this could be enough to cause  your problem.
