Author Topic: On Cab Conversions, what did you do to get seat speakers working?  (Read 5460 times)
Boomslang
Just curious what others did for seat speakers to get them working.
I need to finish off my Daytona USA 2 twin cab conversion and just purchased a twin Sega Rally 2 cab aswell to start on soon
vandale
  • Id 10 and t error
Re: On Cab Conversions, what did you do to get seat speakers working?
« Reply #1 on: March 17, 2015, 03:38:26 am »
Replaced the speakers with 5.1 channel rears and connected them to the 5.1channel amp/sub inside the seat base. Front speakers also installed, centre speaker not. Benefit is you get surround sound on later arcade games and Daytona sounds awesome with 2 channel surround. Put some pics up of your cab
Boomslang
« Reply #2 on: March 17, 2015, 04:15:25 am »
cool I was thinking of doing that but figured id see what others had done. Ill post it up once its all finished, I don't have speakers up front anymore as I converted to 32"" LCD which required getting rid of speakers. Dashboard needs some work still but Its not far off
vandale
  • Id 10 and t error
Boomslang
retrorepair
  • Last login:July 06, 2025, 06:47:43 pm
« Reply #5 on: March 18, 2015, 04:43:53 pm »
Doesn't it already have a sub? I have one here that would fit if not.
I also have a sub amp for that cab here too if you don't have one in there.
I love the Sega seat subs, really rattles your teeth :)
My arcade racing setup:
My Youtube Channel: http://www.youtube.com/user/RetroRepair
My Twitter: http://twitter.com/retrorepair
Boomslang
« Reply #6 on: March 21, 2015, 02:46:22 am »
hmm no I never had a sub with it
Brian74
  • Last login:April 21, 2025, 11:11:53 am
  • Yep... I built that!!
« Reply #7 on: March 21, 2015, 08:14:32 am »
I used logitech 5.1 speaker's wired to a Yamaha receiver.  I took the center speaker apart and mounted it the dash. Sub is inside the cab under the seat.
Boomslang
« Reply #8 on: March 28, 2015, 06:18:42 am »
cool I just brought 2 x Logitech Z506 5.1 setups. Not sure yet if ill actually take out the seat speakers or just wire them up inplace of the actual Logitech rears. I cant remember what impedance the rears were but I believe they were 6 or 8 ohm and im pretty sure the Logitech speakers are 4 ohm but ill check it out. Im pretty sure you can use 6/8 ohm speakers on 4 ohm amp with no issues except lower overall volume, just cant use 4 ohm speakers on a 8 ohm amp etc
then ill have to do the same on the sega rally 2 cab which ive done a bit of work on in last couple weeks now
ryandoesntstress
  • Last login:March 16, 2018, 05:16:26 pm
« Reply #9 on: April 07, 2015, 08:06:18 pm »
I just used the original speakers and purchased a small cheap amp to power them. They sound great other than a faint static when there is no sound being played. http://www.aliexpress.com/snapshot/6322720243.html?orderId=64422699621032
SailorSat
  • Last login:December 16, 2025, 01:58:00 am
    • For Amusement Only e.V.
« Reply #10 on: April 14, 2015, 11:23:28 am »
On my Dayonta USA cabinets, I used the original sound amp (stereo cinch inputs, yeah!) :)
  • Last login:December 19, 2025, 12:23:29 pm
« Reply #11 on: April 14, 2015, 02:24:46 pm »
My Virtual On cab had a tiny sub (4-5"?) facing upward in a plastic box under the seat.
Easy to not realize it's a sub.
You could probably find a replacement with the correct resistance to connect to a Logitech 5.1 setup.
The surround of my original one was completely deteriorated.
