Author Topic: Control panel overlay bubbling at t molding  (Read 1625 times)
lisowskikevin
  • Last login:April 02, 2024, 07:49:55 pm
  • If you take shortcuts, you get cut short.
« on: March 16, 2015, 01:58:30 pm »
Hey guys, anyone have a solution for bubbling of the CPO where it meets the T molding?
lamprey
Re: Control panel overlay bubbling at t molding
« Reply #1 on: March 16, 2015, 03:59:16 pm »
Is it just air or is it no longer sticking?
If it is just air, you should be able to squeegee it out. If it is not sticking you'll need some adhesive or a new overlay. I've noticed before that if the overlay is not trimmed correctly, that the t-molding can push is up once it is tapped into place. So, possibly, you might try trimming the edge..?
lisowskikevin
« Reply #2 on: March 16, 2015, 04:14:01 pm »
It's the second problem. I will trim it up a bit and try an adhesive......wood glue maybe? My cp is painted plywood.
ChanceKJ
« Reply #3 on: March 16, 2015, 04:55:38 pm »
Theres another thread with this where i answer the problem here:
http://forum.arcadecontrols.com/index.php/topic,144153
lisowskikevin
« Reply #4 on: March 16, 2015, 05:01:59 pm »
I knew I read that post somewhere before! Ok I will try that first.
Thanks for the info
ChanceKJ
« Reply #5 on: March 16, 2015, 05:06:07 pm »
make sure its a SHARP and pointy knife.    Don't cut yourself.
lisowskikevin
« Reply #6 on: March 16, 2015, 05:12:49 pm »
Hahaha thanks for the heads up!
