Author Topic: 3/2 screens games with correct aspect ratio and integer stretch  (Read 3370 times)
haynor666
  • retro maniac
I set up almost all games the way I would like but still I have problems with two screens and three screens games. I simply cannot force groovymame to display them with correct aspect ratio using interlaced resolutions. Example is Darius that I want to display using resolution 864x496 but groovymame stretch twice Y resolution. When I set aspect ratio in ini then fractional scalling is applied both X and Y axis. Problem is I want integer scalling in Y axis only. How to disable stretching in Y axis ? I know that such games does not look too good on standard CRT TV but still such games stretched twice look strange.
  • Last login:Yesterday at 08:05:28 am
Re: 3/2 screens games with correct aspect ratio and integer stretch
« Reply #1 on: March 14, 2015, 08:53:22 am »
"cleanstretch 2" does exactly that. But why do you want to use 496i? I don't get why you don't use 864x224 instead.
haynor666
  • retro maniac
« Reply #2 on: March 14, 2015, 09:26:21 am »
I need correct aspect ratio. Using 864x496 and regulating picture through service menu is the best way. cleanstretch 2 with this resolution didn't help because Y axis is still doubled. I switched to 2560x496 and this time I get correct aspect ratio but Y axis is stretched by fractional  multiplier (noticable mostly on highscore screen).
Right now I bypass problem using cleanstretch from cabmame.
« Reply #3 on: March 14, 2015, 10:58:56 am »
Try changing this:
 crt_range0  15625-16200, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.192, 1.024, 0, 0, 192, 288, 448, 576
by this:
 crt_range0  15625-16200, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.192, 1.024, 0, 0, 192, 288, 192, 576
haynor666
  • retro maniac
« Reply #4 on: March 14, 2015, 03:43:45 pm »
This only enabled fractional stretching on both axis. Enabling cleanstretch on force scales Y axis twice.
haynor666
  • retro maniac
« Reply #5 on: July 19, 2015, 05:13:52 am »
Calamity, it there any chance to add option that disables stretching completly? I've managed to cheat mame by enabling vertical stretching to 0,5 for each screen but would be nice to do this just by one option.
« Reply #6 on: July 28, 2015, 04:40:02 pm »
At some point I'll add options to enter a custom independent integer scale factor for each axis.
Ideally this wouldn't be necessary with properly defined crt-ranges, but there will always be specific cases like this one where you need it.
