Author Topic: [bought] coloured dust washers for zippyy & versaball2 shafts  (Read 975 times)
rabidpuppy
  • Last login:July 21, 2015, 06:30:56 am
Hi,
I have 2 long shaft Zippyy's, and 2 Super-Pro Leaf's that have VersaBall2 shafts.   Have red/blue/yellow/green balltops so looking for matching dust washers/covers.
Ideally I'd like to also get matching coloured shaft covers for the Zippyy's as the VersaBall2 shafts already match their balltops.
At least, I'd like to try and get similar sized (outer diameter) washers even if they are just black.  The Super-Pro washers look huge & silly next to the Zippyy washers.
(Yes if I was Mr Money I would just get rid of the Zippyys and get 2 more Super-Pros or similar, am trying to use what hardware I have).
edit: Bought!   Found an online seller who made custom washers, will see how they fit when they arrive.
edit2: Here's what they looked like. LS-32 Version & JLF - W/Shaft Cover hole size from http://tek-innovations.com/arthobbies/?loc=products&cat=7
You can see I got plain coloured versions and Gauntlet character versions (since it is a Gauntlet themed panel), with 2 versions of the Wizard:
« Last Edit: May 22, 2015, 05:52:36 am by rabidpuppy »
