Author Topic: My new Cocktail Table Project  (Read 9497 times)
camperman73
  • Last login:February 26, 2016, 11:38:31 am
« on: March 09, 2015, 07:40:14 am »
Hi all
My new Cocktail project. Thoughts and tips please.
http://how-to-build-a-cocktail-arcade.blogspot.co.uk/
Stu
Re: My new Cocktail Table Project
« Reply #1 on: March 09, 2015, 12:32:20 pm »
How did Defender work out for you on a vertical screen?
camperman73
« Reply #2 on: March 10, 2015, 07:36:07 am »
It was ok TBH. Just had to mess with the controls because I only have 3 buttons. But worked ok using the joystick.
Need to get back on it this weekend. Stop the other half moaning about the garage being full. haha
Just the painting to do, then fix it together.
camperman73
« Reply #3 on: March 12, 2015, 08:49:59 am »
How do I embed pics in here??
  • Last login:Yesterday at 07:04:36 pm
« Reply #4 on: March 12, 2015, 09:07:07 am »
Link from a website like photobucket:
Click on the icon then paste the URL between the tags.
[img]http://forum.arcadecontrols.com/Smileys/default/grin.gif[/img]
Upload the picture as an attachment:
Under the box you typed your post into, there is a "Attachments and other options" link.
Click on it, then on the browse button and select an image to upload.
Allowed file types: txt, jpg, gif, pdf, png, zip, rar, jpeg, skp, svg, ai, gif
Restrictions: 8 per post, maximum total size 5120KB, maximum individual size 2048KB
Generic Eric
« Reply #5 on: March 12, 2015, 09:09:34 am »
Attach please.  That way if your picture host folds or restructures, they will still be hosted here.
camperman73
« Reply #6 on: March 16, 2015, 07:54:08 am »
Thanks folks.
camperman73
« Reply #7 on: March 19, 2015, 08:26:58 am »
Do the buttons look too far apart? I am thinking i have made the controller box too wide.
jdbailey1206
« Reply #8 on: March 19, 2015, 08:57:50 am »
My understanding is just from the Pac Man series cocktail cabs have 2 different sized control panels.
Pac Mans control panel was 11'' which can be referenced from this picture from arcadeshop.com
Also if you reference the Pac Man drawing package here you can see that on page two there is a detailed drawing that shows the total width of the control panel assembly is 12 1/2''.  This includes the two control panel sides that are 3/4" a piece and the internal metal control panel that is 11".
Ms Pac Man is a little different.  Her control panel only comes in at 9".  See below.
Just by guessing, and I feel I'm light in my estimation, it looks as if your CP is over 13".  Just on the inside.
« Last Edit: March 19, 2015, 09:01:43 am by jdbailey1206 »
yamatetsu
  • Last login:Yesterday at 03:56:30 am
  • Just because.
« Reply #9 on: March 19, 2015, 11:19:58 am »
If these buttons are to be action buttons, not admin buttons, they are definitely too far apart. Take a look at the following link (main forum, sticky 'Control Panel Database: Post a picture of your Control Panel!'), where you'll find 24 pages with pics of control panels. I doubt that you'll find a panel that has the action buttons so far apart.
keilmillerjr
  • Web Developer.
camperman73
« Reply #11 on: March 20, 2015, 10:31:25 am »
Cheers for the replies. Think i will start again with the board.
camperman73
« Reply #12 on: April 07, 2015, 05:19:27 am »
Painting, painting and more painting
So after 3 coats of under coat, and 5 top coats I am nearly there.
I am getting obsessed with getting the finish perfect. So another rub down and final coat and i should be done.
I took some advice from contributors on http://forum.arcadecontrols.com/ about the spacing of the buttons. So i decided to reduce the gap between them and shorten the width of the control panel.
It look fine, so I am quite happy with it.
I bought some small caster wheels for underneath, so its easier to move. Its quite heavy even without the pc and monitor in there.
BobA
  • What Me Worry?
« Reply #13 on: April 08, 2015, 07:05:44 pm »
Spacing of play buttons looks much better.  :applaud:
camperman73
« Reply #14 on: April 10, 2015, 03:44:20 am »
Thanks. Now im thinking of adding a fourth. What do you reckon?
camperman73
« Reply #15 on: April 13, 2015, 03:51:31 am »
Anyone have any thought on the fourth button?
Some updated pics below.
Added the side fan.
johnrt
« Reply #16 on: April 13, 2015, 05:52:49 am »
I think it looks better with just 3 buttons. I would have made the CP like this if I would use 4 buttons: (a Neo-Geo layout)
camperman73
« Reply #17 on: April 13, 2015, 07:08:17 am »
Thanks johnrt. Was thinking I might allow more games. But you are probably right.
3 kinda looks ok.
Maybe do the next one with 4.
Is there a list of 3 or less button games?
And a list of flip cocktail games?
Also, is it easy to flip standard games to play two player. Or just specific games that work that way?
johnrt
« Reply #18 on: April 13, 2015, 07:41:52 am »
According to Don's HyperSpin List Generator:
You can play 5047 games with 3 buttons and 5866 with 4 buttons.
(You can apply many filters in Don's Hyperspin List Generator)
http://honerbrink.com/?cat=7
camperman73
« Reply #19 on: April 13, 2015, 09:30:13 am »
Great thanks. I think 3 will be fine then haha!
camperman73
« Reply #20 on: April 20, 2015, 05:28:52 am »
Finally got around to starting the wiring. Had to extend the wires to the controller. Soldered nice and neat.
camperman73
« Reply #21 on: April 22, 2015, 09:59:57 am »
Some more pics after wiring.
Added a set of speaker. Wired network cable.
Now onto installing HyperSpin. Mame works great.
Just have to trim the game list a little.
camperman73
« Reply #22 on: April 22, 2015, 10:02:08 am »
Quick joystick question.
The joystick guard underneath, I have it set as 8 way rather than 4.
This seems better for some games like 1942.
But playing pacman is a little hit and miss.
Would you suggest sticking the joystick guard as a 4 way rather than 8?
yamatetsu
  • Just because.
« Reply #23 on: April 22, 2015, 10:33:38 am »
That depends on what you want to play. If you only want to play 4-way games, set it to 4-way. For anything else, set it to 8-way. This will probably lead to frustration when playing 4-way games, though.
Another alternative would be to set up the left joystick as 8-way and the right one as 4-way. This would however eliminate two-player-simultaneous-8-way-games.
If you want to be able to play both types of game comfortably, you either need a switchable stick like the ServoStik or a programmable one like the UltraStik360.
camperman73
« Reply #24 on: April 23, 2015, 09:22:29 am »
Thanks yamatetsu
I might try the 4 way and see how i get on. Thanks
camperman73
« Reply #25 on: April 30, 2015, 04:31:12 am »
I started to add the chrome strips. They look great against the white. Nice and clean lines.
Time consuming but worth it.
Next time i will use 12mm wood and t-molding. But you live and learn.
I also bought some LED strips for underneath. It will match the blue LED fan.
Thoughts?
camperman73
« Reply #26 on: May 05, 2015, 04:31:59 am »
HELP!! HYPERSPIN
Sorted i think
« Last Edit: May 05, 2015, 11:15:13 am by camperman73 »
camperman73
« Reply #27 on: May 14, 2015, 03:40:41 am »
After wrestling with Hyperspin and Xpadder for a while. I finally have it all working.
I added the LED strips underneath.
Next jobs. Speakers.
From the pics do you think the monitor looks too small.
I was thinking of a 24 inch TV rather than the 19 inch monitor.
Thoughts?
camperman73
« Reply #28 on: May 14, 2015, 03:41:52 am »
My other thought. Someone said the corners are too round? Should i reduce the radius?
camperman73
« Reply #29 on: May 20, 2015, 04:04:08 am »
I have decided to change the top. Reduce the radius of the corners.
I got a 24inch tv and stripped that down. Removing the dvd player.
I have to find somewhere to house the infra red receiver for the tv so I can turn it on.
I finally added the speakers. And the air grills i bought.
I think they look ok in chrome.
camperman73
« Reply #30 on: May 27, 2015, 11:10:00 am »
Couple of updated pics. Need to make a new top. And mount the tv controls or infra red reciever somewhere.
But its nearly complete.
SpaceHedgehog
  • Last login:March 14, 2026, 10:40:09 am
  • Almost done ...
« Reply #31 on: May 27, 2015, 02:04:14 pm »
snip.
Best way to be. If you're anything like me, you'll just focus on the things you didn't do right otherwise.
The build looks great. I'd love a cocktail cabinet.  :cheers:
Click a pic for a video tour
camperman73
« Reply #32 on: June 02, 2015, 08:27:18 am »
Decided to stick with the top.
Added a USB port to the side so you can add games, music, movies etc.
Added the chrome to the outer and inner edge of the top.
Wired the infra red for the TV, so you can switch it on when the lid is on it.
Last job is to get the perspex for the top.
Going to go with perspex rather than glass. Short cut i know.
camperman73
« Reply #33 on: June 15, 2015, 08:51:27 am »
All working. Got the other half to test it out.
Just waiting for the toughened glass top to come back and its complete.
Will add final pics soon as.
camperman73
« Reply #34 on: July 06, 2015, 06:34:11 am »
COMPLETE:
Got the toughened glass in the end.
One tweek i had to do was to remove the infra red for the tv and added a button to switch it on instead.
Added 800 Mame games, 800 Sega Genesis games, 40 Vectrex and a few pinball games.
Some videos of it working.
deano71
  • Last login:August 30, 2015, 08:30:15 am
« Reply #35 on: July 06, 2015, 03:17:58 pm »
Looks good mate.
camperman73
« Reply #36 on: July 07, 2015, 03:38:04 am »
Thanks  :) :) :) :) :)
yamatetsu
  • Just because.
« Reply #37 on: July 07, 2015, 12:04:50 pm »
Nice build !  :applaud:
