Author Topic: Possibility to adjust brightness/contrast via OS (linux, terminal)?  (Read 1915 times)
emuola
  • Last login:June 15, 2017, 02:19:54 am
I was wondering if it is possible to adjust brightness and/or contrast from Linux and more specifically terminal (running GroovyArcade)? I found some packages in Archwiki, but I'd want to be sure I'm not gonna mess the whole system.
I'd like to do some tests with different contrast levels without the need to open the cab and use the manual monitor controls.
Is this possible?
GroovyArcade (ArchLinux)
Ati X300
Makvision M3129
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
Re: Possibility to adjust brightness/contrast via OS (linux, terminal)?
« Reply #1 on: March 08, 2015, 07:49:39 am »
Use the slider controls built into MAME/UME ?
emuola
« Reply #2 on: March 09, 2015, 03:22:14 am »
Doh! Stupid me. Thanks. Will try that  :notworthy:
