Author Topic: Lethal Enforcer - Completed  (Read 5522 times)
otsep
  • Last login:September 28, 2025, 02:53:45 pm
  • I'm your huckleberry...
« on: March 05, 2015, 03:53:12 pm »
I'm working on a Lethal Enforcer cab and it's PSU is blown.
Should I use a standard arcade power supply knowing the outputs from the old one or try and keep it original and do a repair?
« Last Edit: April 29, 2015, 12:36:31 pm by otsep »
Vids: Namco Rockin' Bowl-O-Rama
Pins: Aerosmith Pro, ST Premium Vault, Beatles Gold
Remember Wheaton's Law
Re: Lethal Enforcer - Power Supply Help
« Reply #1 on: March 05, 2015, 04:24:23 pm »
Upgrade the PSU.
otsep
« Reply #2 on: March 05, 2015, 04:29:12 pm »
Upgrade the PSU.
So just buy a new one from Suzo Happ?
« Reply #3 on: March 05, 2015, 04:40:28 pm »
Doesn't matter really where you buy it from, Suzo Happ, Jammaboards, Paradise arcade, even divemaster127 has a bunch of PSU's in stock.
Just as long as you grab one that has +5v, 12v, and -5v since your board requires all three.
otsep
« Reply #4 on: March 05, 2015, 04:43:54 pm »
I was thinking about using a standard arcade power supply, but the lure of an easy plug-n-play is strong.
otsep
Re: Lethal Enforcer - Electrical Issue
« Reply #5 on: March 16, 2015, 10:01:42 pm »
So I replaced the power supply and I heard an arcing noise.
I noticed that the cart board is arcing from what I believe is the flyback wire.  It seems this wire is cracked further down the line.
Can I repair this?
ed12
« Reply #6 on: March 16, 2015, 10:44:55 pm »
holy ---steaming pile of meadow muffin--- u did not see that brunt and black wire ?
orange across /yellow/black peeling out ?
u did not note 3/4's of that wire is exposed ?
:note: the heat sink is a ground...
ed
otsep
« Reply #7 on: March 16, 2015, 10:50:39 pm »
ed
I heard the arc and looked for it and noted what I saw.  I've never worked on this cab before and I'm looking for guidance.  There is still a lot of crud on the wiring I'm trying to clean out and I'm not exactly sure where you see the burn as I may have thought it's crud build up.
On the higher res photo, it looks like crud.
otsep
Re: Lethal Enforcer - Electrical Issue Identified - Need parts
« Reply #8 on: March 22, 2015, 04:19:06 pm »
I was able to fiddle around with it a little more and definitely identified the issue.
The JAMMA PCB appears to be in good shape.
Looked at the ISO Board? for any burns, etc and it looks clean.
After a closer examination which involved partially pulling out the board, none of the previously recommended wire issues existed.
As I originally thought, the flyback transformer is bad.  The unit is shorting at the top of the flyback where the anode wire attaches.
I looked on SuzoHapp and could not find the part description or number.  Does anyone have any experience with this type of machine?  Is there a comparable model I might be able to use parts from?
When I worked in a repair shop 20 years ago, we never replaced these parts, just ordered a new board.
Any insight would be appreciated.
« Last Edit: March 22, 2015, 04:21:34 pm by otsep »
matsadona
« Reply #9 on: March 25, 2015, 05:09:04 am »
It is probably easier to replace the whole chassie board, than finding and replacing just the fly back. But that is just how I would do.
By the way, you should be happy having a Lethal Enforcers board with a good sound circuit, since they are known for dying...
« Reply #10 on: March 25, 2015, 12:15:22 pm »
What monitor is it?
otsep
« Reply #11 on: March 25, 2015, 12:17:04 pm »
What monitor is it?
It looks like a standard CRT to me. Is the a specific place I can pull an identifier.
« Reply #12 on: March 25, 2015, 01:33:54 pm »
Any stickers on the tube or chassis mount?  There should be something there that says what it is.  Or perhaps within the manual?
There is no such things as a "Standard CRT".  There are quite a few different CRT's out there, with different features like mid-res/high-res support, sync polarity, etc., that require different specific parts. There are no parts that are standard between all CRT's...
otsep
« Reply #13 on: March 25, 2015, 02:01:39 pm »
I should have said "regular". As in nothing noticed that was unusual or out of the ordinary.  I'll see what kind of markings I can find when I get home.
otsep
« Reply #14 on: March 28, 2015, 11:16:19 am »
It appears to be a Polo CRT according to the manual.  I'm looking for a replacement chassis now.
otsep
Re: Lethal Enforcer - Possible Parts Found - Need advice!
« Reply #15 on: April 02, 2015, 10:48:53 am »
So I found this fairly close to the house.
http://tampa.craigslist.org/psc/ele/4878682035.html
Assuming it's working, I should be able to use the CRT in the Lethal cab, right?
otsep
« Reply #16 on: April 02, 2015, 03:02:00 pm »
Let me elaborate.  I'm hoping to determine what, if any, feature is a must have on the crt for the cab.  I've googled around and haven't been able to locate any good info.  Aside from verifying that it turns on, any pointers would be appreciated.
This is a 1.5 hour drive for me and I want to be sure the gas, tolls & time are not wasted.
  • Last login:Today at 01:02:43 am
« Reply #17 on: April 02, 2015, 04:29:52 pm »
Send your chassis to Arcadecup.com and save half the cost and all of the gas.
otsep
« Reply #18 on: April 02, 2015, 09:48:14 pm »
Sigh.  You're right, yotsuya.  I was hoping my first cab find would be more fun, but I'll probably just end up sending it off.
Before I do, I'm going to pull the board and make sure everything is working.
otsep
Re: Lethal Enforcer - Completed
« Reply #19 on: April 29, 2015, 12:45:33 pm »
Happy to report that the cab is working!  :woot
Final tally
- Cleaned inside & out
- Replaced the power supply
- Replaced CRT
- Rewiring (Bypassed lockout switches, etc)
My only complaint is the board test sound is REALLY loud. :o Scares the crap out the guy's dog every time. :scared
matsadona
« Reply #20 on: April 30, 2015, 02:50:22 am »
Sweet! Well done and enjoy your game  :applaud:
By the way, Killer Instinct has a "need to change your pants" boot sound as well  ;)
