Author Topic: Does V hold vary from board to board?  (Read 1614 times)
« on: February 26, 2015, 01:08:52 pm »
For those of you running original hardware and switching or swapping JAMMA.  How much to you have to adjust your monitor after a swap?
I'm worried that my whole concept of multiple JAMMA boards is going to come crashing down if I have to adjust the ---gosh-darn--- v hold every time I change games?
It seems like Maximus complained of something similar in his Ikari/Heavy Barrel build.  Does anyone else have a similar problem and or a solution?
CraftyMech
  • Last login:July 29, 2023, 08:08:45 pm
  • I love the smell of solder in the morning...
    • craftymech.com
Re: Does V hold vary from board to board?
« Reply #1 on: February 27, 2015, 12:42:38 pm »
Both V & H hold adjustments may be necessary when swapping boards, but not so much with JAMMA boards in my experience (just occasionally).
V/H position on the other hand may need to be adjusted more often, but if your monitor has a remote board you can stash that in the control panel for easier access.
4-6 board switchers have been used in some nice setups, depending on your chassis, you just have to fiddle with the H/V position pots until you find a happy medium that works for all the games you have in the cab.
« Last Edit: February 27, 2015, 12:45:57 pm by CraftyMech »
BitKit 8bit FPGA Multi - http://craftymech.com
  • Last login:Today at 02:35:55 pm
« Reply #2 on: February 27, 2015, 01:00:21 pm »
Dude, I mean.  Really.  C'mon.
 :notworthy:
If the hold didn't vary between boards - why would that adjustment be on the chassis?
« Reply #3 on: February 27, 2015, 01:37:39 pm »
so in other words, don't screw down my monitor access panel  :-\ ....  Admittedly I need to wait til I get a few more boards to see how big of an issue this might be, I just noticed it when testing my non functioning Strikers board after I had Raiden II looking pretty decent.
pbj.... dude... I like your style man.... never change....
« Reply #4 on: February 27, 2015, 01:57:41 pm »
Does your monitor have a remote board?  My Nanao MS9 in my New Astro City has one that is accessible from under the CP. Makes good for quick adjustments.  I'm assuming since your cab is a Dynamo, it was probably fitted with a WG of some kind?  Not sure if they made remote boards for them...
« Reply #5 on: February 27, 2015, 02:37:22 pm »
they make em, but mine doesn't have one.  I thought about ordering one from Twisty Wrist and trying to figure out how to self install.
« Reply #6 on: February 27, 2015, 02:55:06 pm »
Desolder the adjustment knob, solder some long wires to it, resolder, mount in convenient location.
