Author Topic: WG7000 19" vs 25" strange behavior  (Read 1740 times)
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
« on: February 25, 2015, 01:22:30 pm »
Been quite a while since I've been here...
I donated my MAME hardware to the arcade I work for after be'n sucker'd into fixing someone's mess (2019 in 1 hack job). The setup ran flawlessly in my cab which has a 19" WG7000 std res monitor. After installing it in a 25" cab with a 25k7197 (std res right?) I can't get the vert freq to lock. Should anything need to be changed to keep a 25" happy?
Calamity
  • Moderator
  • Last login:Today at 04:11:38 am
  • Quote me with care
Re: WG7000 19" vs 25" strange behavior
« Reply #1 on: February 25, 2015, 03:47:21 pm »
Check the polarities. It looks like your monitor has separate pins for positive and negative sync polarities: http://www.jammaplus.co.uk/forum/forum_posts.asp?TID=59743&PID=588978&title=problem-with-vsyncmy-arcade-is-a-nightmare#588978
You can theoretically change the polarities both from VMMaker and GroovyMAME custom timings. Let's see if finally someone confirms if this works.
Steps to create a log:
boardjunkie
« Reply #2 on: February 25, 2015, 03:57:14 pm »
It uses neg H/V sync via the Ultimarc video amp. This setup worked great in my cab at home. I just didn't know if going from a 19 to a 25 K7000 needed adjustments.
boardjunkie
« Reply #3 on: February 25, 2015, 04:16:51 pm »
Disregard. Turned out to  be a bad VGA cable. That part is ok now....but I need to find out why MaLa is not seeing 4 gamepad boards....
