Author Topic: Seeburg 3WA Contact Arm Issue  (Read 1748 times)
outandabout24
  • Last login:February 19, 2015, 09:17:29 pm
« on: February 19, 2015, 08:30:18 pm »
Hello,
New with rebuilding jukeboxes and new to the forum.
I have a Seeburg 3WA wallbox that I have powered on.  When I insert a coin and make a selection everything works fine.  However when I make a selection from the second row of letters the rotating contact arm will rotate around, stop, reset the letter and number that was selected but then continues to rotate around again and again till all of the plays are gone.  Not only does the rotating arm move but also the mechanical device behind the letters and numbers.  Any help is appreciated!
Josh
