Author Topic: Video settings different for each game?  (Read 911 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« on: February 19, 2015, 05:52:57 pm »
I'm noticing that some games require me to adjust their video because they are too bright.  I enabled HLSL by the way. I thought that video settings are kept the same for all ROMS.....maybe I'm not configuring it at the right place such that it can be done once and have it applied to all titles.
lamprey
Re: Video settings different for each game?
« Reply #1 on: February 20, 2015, 11:53:07 am »
Hard to say.
You could try wiping out the NVRAM and CFG files. Also, verify that you don't have other INI files overriding the mame.ini (presumably in the INI directory).
bulbousbeard
  • Last login:August 25, 2015, 11:58:25 pm
« Reply #2 on: February 21, 2015, 11:24:46 am »
Different games have different gamma levels. Some per-game settings are unavoidable.
You could also just change commandline args such as brightness, gamma, etc.
For example, mame.exe kof98 -gamma 0.5 -brightness 0.4 works.
The nice thing about just putting those things in the command line when you launch the game is that you have no dependency on MAME cfg files. You could nuke a directory and still have all your settings.
I also highly recommend using MAME's volume arg to normalize the sound across different games. For example, this will run the game at -11db:
kof96 -volume -11
As far as INI files go:
MAME takes things such as horizontal.ini for all horizontal games, vertical.ini for all vertical games.
You can also use the name of drivers. neogeo.ini will apply to all Neo Geo games, and cps2.ini will apply to all CPS2 games.
