Author Topic: MELTDOWN Wide Vewlix Style Build - Major backlog updates  (Read 20414 times)
Electronuclear
  • Last login:May 25, 2017, 10:32:29 pm
Re: MELTDOWN Wide Vewlix Style Build - Major backlog updates
« Reply #40 on: May 31, 2015, 10:06:00 pm »
Here's the primer coats.  It ended up taking three coats.  All though I probably could have gotten away with two:
IMG_0971 by Michael Moore
IMG_0972 by Michael Moore
IMG_0973 by Michael Moore
IMG_0974 by Michael Moore
IMG_0977 by Michael Moore
IMG_0978 by Michael Moore
IMG_0979 by Michael Moore
IMG_0980 by Michael Moore
And of course after each primer coat, I used Timbermate to fill in the holes (much like other people have used bondo)
IMG_0981 by Michael Moore
IMG_0982 by Michael Moore
IMG_0983 by Michael Moore
IMG_0984 by Michael Moore
IMG_0985 by Michael Moore
IMG_0986 by Michael Moore
Electronuclear
« Reply #41 on: May 31, 2015, 10:10:21 pm »
Here's the green and black.  My son really loves the "neon green" type color, and I couldn't think of a better color to represent something that is radioactive.
IMG_0990 by Michael Moore
IMG_0991 by Michael Moore
IMG_0996 by Michael Moore
IMG_0997 by Michael Moore
IMG_1001 by Michael Moore
IMG_1003 by Michael Moore
IMG_1005 by Michael Moore
IMG_1010 by Michael Moore
IMG_1011 by Michael Moore
IMG_1012 by Michael Moore
IMG_1013 by Michael Moore
IMG_1015 by Michael Moore
IMG_1017 by Michael Moore
IMG_1016 by Michael Moore
IMG_1018 by Michael Moore
« Last Edit: May 31, 2015, 10:15:38 pm by Electronuclear »
Electronuclear
« Reply #42 on: May 31, 2015, 10:19:35 pm »
Getting ready to mount the TV in, for the bezel I will be using plexiglass spray painted black.  To hold the plexi in place, I'm going to glue on these metal pieces, that will be held by magnets.  I put a spring loaded push and release one at the top left corner to make it easiier to remove if need be.
IMG_1023 by Michael Moore
IMG_1024 by Michael Moore
IMG_1025 by Michael Moore
And here's the CP panel with the graphic and plexi in.  What do you guys think?
IMG_1026 by Michael Moore
With buttons in:
IMG_1028 by Michael Moore
Electronuclear
« Reply #43 on: May 31, 2015, 10:21:11 pm »
Working on wiring most of today.  Once finished I will post some pictures of how it turned out.  This is day 2 of wiring.  So far it is coming along pretty good.
IMG_1031 by Michael Moore
« Reply #44 on: May 31, 2015, 11:50:42 pm »
To get the final shine on my machine I will be using a procedure called "rubbing out"
PBJ mentioned rubbing one out all summer, until DeLuSiOnaL29 censored him.  :laugh2:
harvardman
  • Last login:January 28, 2017, 06:12:23 pm
Been doing a lot of work on this thing.  Build seems to be coming along nicely.
Things to finish up:
-Top of the cabinet where the round part is
-Control Panel
-Finishing and Painting
-Wiring and installation
Trying to come up with some different artwork taking into account some of the feedback that I have received.  Preliminary artwork, let me know your thoughts
Marquee Meltdown 2 by crymicmoore
Some wood cutting here:
IMG_0669 by crymicmoore
IMG_0679 by crymicmoore, on Flickr
Assembly of the base
IMG_0684 by crymicmoore
Routing out vent louvers
IMG_0677 by crymicmoore, on Flickr
Need to get some hinges, but just test fitting, seems to fit pretty well.  There is a small gap (1/8" or so on the right corner).  Not too sure what happened there, maybe the circular saw tracked inward on me when I was cutting.  I don't mind so much as this will be on the back of the panel.
IMG_0687 by crymicmoore
Cut the sides
IMG_0688 by crymicmoore
Assembled those with the TV mount
IMG_0689 by crymicmoore
Front view
IMG_0690 by crymicmoore
Test fit of the coin door, "llllllllllike a glove"
IMG_0671 by crymicmoore
is there any chance you could share measurements ? please as I want to build a wide screen 2 player or 4
