February 07, 2026, 04:43:25 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Arcade Collecting
Miscellaneous Arcade Talk
English Mark super six trouble shooting
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: English Mark super six trouble shooting (Read 3527 times)
rwaechter1
Trade Count:
0
Full Member
Offline
Last login:February 26, 2015, 03:19:00 am
I want to build my own arcade controls!
on:
February 15, 2015, 11:33:14 pm »
Picked up a cheap board the other day and took the whole playing segment apart to clean out broken tips stuck in the segments. When I put it back together all of the segments under the 20 and 1 won't register but every other segment does on the board does
. I'm sure it's got to be something simple but does anyone have any ideas what happened?
Logged
rwaechter1
Trade Count:
0
Full Member
Offline
Re: English Mark super six trouble shooting
Reply #1 on:
February 15, 2015, 11:49:32 pm »
And before anyone asks yes these segments worked when I got it
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Last login:October 12, 2021, 12:25:59 am
Technician
Reply #2 on:
February 16, 2015, 01:37:31 pm »
Is this the "Standard Spider" or "Super Spider" target head?
Did you reassemble it correctly?
Did you carefully plug everything back in?
Logged
rwaechter1
Trade Count:
0
Full Member
Offline
Reply #3 on:
February 16, 2015, 03:28:30 pm »
Yes sir it's only one plug (wide single ribbon style) super spider and all the other sections work perfectly. I've seen at least one other post that the same thing happened where the 1s and 20s wouldn't work. Any idea if this is a common problem?
Last Edit: February 16, 2015, 03:33:39 pm by rwaechter1
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Technician
Reply #4 on:
February 16, 2015, 05:13:41 pm »
The target head screws should only be put in finger tight. Anything tighter will bind/press/damage the switch matrix.
Also, be sure the faces of the switch matrix and the rubber mat are cleaned thoroughly with lighter fluid.
Logged
Trade Count:
+4
Full Member
Offline
Last login:
Yesterday
at 12:54:01 pm
Obey.
Reply #5 on:
February 16, 2015, 05:19:19 pm »
Probably not tightened enough on the bottom screws. If you do it too tight, the game will let you know quite loudly.
Logged
rwaechter1
Trade Count:
0
Full Member
Offline
Reply #6 on:
February 16, 2015, 07:49:49 pm »
Really lighter fluid? Lol I used windex and it didn't make a difference. The white composite board goes on with round plastic nuts so those are finger tight. I found a schematic used to test whether it's the matrix itself by opening and closing loops so I'm going to try that and see what I can find out. I appreciate the help guys!
Logged
Karetaker
Trade Count:
+1
Full Member
Offline
Last login:July 28, 2022, 08:19:40 pm
Reply #7 on:
February 16, 2015, 08:21:07 pm »
This is going back quite a few years but I believe these have a back that snaps into each segment. If that is the case make sure you have them snapped tight. If they are not in correctly they will cause this.
Logged
rwaechter1
Trade Count:
0
Full Member
Offline
Reply #8 on:
February 16, 2015, 08:58:37 pm »
Yes you are correct about the snaps on the segments. I just checked them and they look ok
Logged
rwaechter1
Trade Count:
0
Full Member
Offline
Reply #9 on:
February 16, 2015, 11:26:54 pm »
Just messing around I flipped the matrix over just to see if all locations register and they do. Wtf!
Logged
Trade Count:
+4
Full Member
Offline
Last login:
Yesterday
at 12:54:01 pm
Obey.
Reply #10 on:
February 16, 2015, 11:51:48 pm »
Sounds like you fixed it
Logged
rwaechter1
Trade Count:
0
Full Member
Offline
Reply #11 on:
February 17, 2015, 11:02:08 am »
It registered but not the right numbers. Flipped at back the other way and it again wouldnt register. Ken you seem like you know alot about these is it very common for specifically the 1s and 20s to go dead if the matrix is bad? Are any board connections that might cause something like this? I cleaned all the boards with electronics cleaner
Logged
rwaechter1
Trade Count:
0
Full Member
Offline
Reply #12 on:
February 17, 2015, 11:44:36 am »
Also will a super spider from a galaxy work for my application? Are all super spiders the same?
Last Edit: February 17, 2015, 12:25:32 pm by rwaechter1
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Technician
Reply #13 on:
February 17, 2015, 10:44:19 pm »
Don't know the answer to that question. We dumped all our Arachnid machines off the route and switched over completely to Medalist "Dart Star" machines over 20 years ago.
Logged
rwaechter1
Trade Count:
0
Full Member
Offline
Reply #14 on:
February 24, 2015, 02:50:09 pm »
Ended up being the matrix. Ordered a new one put it in and good to go. Thanks for the input guys
Logged
Ken Layton
Guru
Trade Count:
+1
Full Member
Offline
Technician
Reply #15 on:
February 25, 2015, 01:36:20 pm »
The power supply and switch matrix were the most common & expensive failures on Arachnid equipment. That's why my boss switched to Medalist dart boards instead.
Logged
rwaechter1
Trade Count:
0
Full Member
Offline
Reply #16 on:
February 26, 2015, 03:19:00 am »
See and I never thought it would've been that because it worked perfect before I took it apart and I made sure to be careful with it but who knows that was probably the first time it had been apart in 10-15yrs.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Arcade Collecting
