Author Topic: HD failed, cam I install new HD image using USB?  (Read 3702 times)
popcorn1
  • Last login:October 02, 2021, 01:01:06 am
« on: February 14, 2015, 12:04:12 pm »
ION system (aurora 2010)
Is it possible to install a new HD image to a fresh drive using just the USB port? I don't have the Centronics adaptor. I know I can just open the game up and connect a dvd, I was just hoping that USB was an option for this and I simply havent stumbled on the right sequence. I have the disk images DL'd from the legacy site.
Thoughts?
mahkeymike
  • Last login:Yesterday at 11:16:56 am
Re: HD failed, cam I install new HD image using USB?
« Reply #1 on: February 14, 2015, 02:23:11 pm »
No its not possible. The ISOLINUX file system merit used does not support usb. It will boot but once everything is passed over to the the installer, it will fail with kmod errors. The amount of work involved to rebuild with usb support would not be worth it. Dont be lazy. Just hook up a ide cable and use any ide dvd rom drive. Or if you have the ASUS or Intel motherboard you could use a sata dvd rom drive aswell.
popcorn1
« Reply #2 on: February 14, 2015, 03:23:12 pm »
Copy that. Had to ask.
Whats with the awful captcha on every post?
  • Last login:October 16, 2025, 06:18:08 pm
« Reply #3 on: February 21, 2015, 11:10:09 pm »
you are new. captcha will go away eventually.
