Author Topic: Mix 12V and 5V with pacled64  (Read 4470 times)
herve
  • Last login:September 20, 2017, 03:35:24 pm
« on: February 11, 2015, 11:56:15 am »
Hi all,
First I'm sorry for my poor English (French Inside  :dunno), but I search a reply to my question and the only forum which I find is here :angel:
Well, I realise my first arcade cabinet and I would like a control panel with a control of led for sticks and buttons.
So I have bought pacled64 from arcadewolrd (better place I think for my country) with 1 pacled64, 2 illuminated joysticks 12V power, 16 ultralux RGB illuminated arcade buttons, and some chrome effect illuminated buttons 12V power.
I would like to power the pacled64 by 12V and connect all leds from buttons and joysticks to it. I had not data sheet, and now, I see a big problem : RGB illuminated arcade buttons have 5V power!
So, I would like to know if it's possible to mix 12 V and 5V powers (I know it's possible to use two pacled boards but it's very expensive with the price of the card and the shipping). I do not have much knowledge in electricity and electronics, so i take an idea from pacdrive web site in the part called 'Advanced Connection Methods'  : http://www.ultimarc.com/pacdrive.html
So Is is possible to realise connections like in the attachment or is it crazy  ??? (Grounds from 12V and 5V power supplies are connected)
« Last Edit: February 11, 2015, 12:16:19 pm by herve »
johnrt
Re: Mix 12V and 5V with pacled64
« Reply #1 on: February 11, 2015, 01:29:24 pm »
Yes, that's possible! As long as +5V and +12V has common ground it should work fine.
herve
« Reply #2 on: February 11, 2015, 01:59:29 pm »
THANK'S A LOT !!!!! :applaud:
I'm very happy from your reply   ;D  I was already imagining not control 12V powered leds... :banghead:
Just a last point. If I put 5V to powered the pacled64, an external power for 12V leds with a common ground, it shoud work fine too ?
(inversion of 5 and 12 V in the picture)
« Last Edit: February 11, 2015, 02:07:04 pm by herve »
johnrt
« Reply #3 on: February 11, 2015, 02:14:56 pm »
Ok... wait a minute. The PacLED requires +5V. Right? That means you can not power the PacLED from a 12V power source. So the ineversion of the picture is the correct one. (Assuming the PacLED requires 5V).
herve
« Reply #4 on: February 11, 2015, 02:21:44 pm »
OK, I'll try the second picture !
johnrt
« Reply #5 on: February 11, 2015, 02:25:49 pm »
Yes, do NOT connect 12V directly into the PacLED!
herve
« Reply #6 on: February 11, 2015, 02:54:55 pm »
Ok, I understand  ;)
Thanks !
herve
« Reply #7 on: February 15, 2015, 09:32:08 am »
Tested today !
I use 12V external power and 5V internal power delivered by pacled64. It works perfectly!
« Last Edit: February 15, 2015, 09:33:41 am by herve »
jaharr01
« Reply #8 on: February 15, 2015, 12:13:08 pm »
Okay don't put 12V to the PAC LED. Use a relay board for anything over 5v or you will burn the Pac LED up
