Author Topic: need help fixing arcade on/off switch  (Read 2183 times)
laruetl77
« on: February 09, 2015, 11:46:50 am »
switch hi new to arcade controls so hope I'm in right spot,ive got a multi arcade machine that I'm wanting to get the on off toggle switch working,right Now when I plug it in it powers up and I'm wanting to fix this so that I can have multiple machine on one surge protector and turn on the machines as needed, I'm actually not sure what exactly it is it's the 2100 in 1 Jamma board so I guess it's not considered a Mame, so there's 4 wires from the on off toggle switch that are taken off towards bottom of machine. The pic with the outlet in it has the ends of the wires to the on off switch, red with white stripe , blue, brown black with white stripe.Was hoping someone could steer me where I would connect these or if there's a easier way. I have several pics but I can't post any due to size limit ,is there a better sit to list pics so you guys can see what I'm talking about Thanks
  • Last login:Today at 03:26:23 pm
Re: need help fixing arcade on/off switch
« Reply #1 on: February 09, 2015, 09:50:18 pm »
MTPPC
« Reply #2 on: February 16, 2015, 11:13:30 am »
I tried reading what you wrote 4 times and all I did was get a headache. Punctuation is designed to separate one thought from another. Use it.
http://pinballmd.com/
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« Reply #3 on: February 16, 2015, 03:13:58 pm »
I was going to help with this one too, but I'm just as confused as the OP.
Can you rewrite your post to be more clear?
behrmr
« Reply #4 on: February 16, 2015, 03:26:10 pm »
Find a way to resize the pictures and post them.  No-one wants to help you electrocute yourself or burn your house down.
