Author Topic: Advice on removing a scratch from plastic  (Read 3423 times)
mike boss
« on: February 05, 2015, 03:26:42 pm »
I bought some Veranda closet doors from Home Depot.
The panel is scratched.
Wanted to ask a question of you restoration guys.
Not sure what the warranty will cover here.
Should I have to polish this out is there a way I can do so where it will remove the scratch  but not damage (or alter the look) of the entire panel ?
Re: Advice on removing a scratch from plastic
« Reply #1 on: February 05, 2015, 04:11:18 pm »
Did you scratch it? If not, take that ---steaming pile of meadow muffin--- back.
mike boss
« Reply #2 on: February 05, 2015, 07:07:08 pm »
We didn't do it.
These are in my front hall and depending on the light you can't see them.
(Which is quite a piss off) as I wish I had noticed before the install.
Sadly we had cut the track and begun the install and noticed once installed.
I'm waiting on the warranty response.
But should I be stuck with the door I want to polish it out.
I'm just not regular user of Novus. So I don't know if the surrounding area would show effects.
behrmr
« Reply #3 on: February 05, 2015, 10:33:44 pm »
Novus 1 2 3 system may work. I have removed some pretty nasty scratches from plexi bezels and marquees with it.
  • Last login:Yesterday at 04:59:46 pm
« Reply #4 on: February 05, 2015, 10:42:42 pm »
Honestly I'd squirt a little lighter fluid on it and see if it optically disappears.  If it does, shoot it with polycrylic clear coat and you'll be good to go.
Or... Wax it?
