Author Topic: Bartop Arcade - Resonant Frequency - Speaker Hum  (Read 1558 times)
newoski
  • Last login:February 26, 2021, 07:44:50 am
« on: February 03, 2015, 08:24:39 pm »
Hi Guys,
I'm having a serious problem with a resonant frequency. The only game I've noticed the problem is Fix It Felix Jr. 14.wav, from the data folder, ends up with some serious hum right at the end of the wav.
Is there anything that can be done to dampen resonant frequencies in a completed bartop build?
Durrrrrrrr
DietCoke
  • Last login:October 10, 2020, 08:32:13 pm
Re: Bartop Arcade - Resonant Frequency - Speaker Hum
« Reply #1 on: February 03, 2015, 08:43:58 pm »
If it is just one wav, why not just edit the hum out?
http://audacity.sourceforge.net/
j.fitzenr
  • Last login:August 28, 2018, 05:07:01 pm
  • Don't Afraid to be Great
« Reply #2 on: February 04, 2015, 10:31:59 pm »
I'm not entirely sure what the issue is: is it hum in the file?  A problem with the playback, amp, connection, etc, or is it for sure just a physical resonant frequency?
I've actually never (yet!) built an arcade cab but I'm a musician/producer/etc. by trade.  (Far from an expert on the physics of it, tbh) but if it's merely a matter of resonance there's probably a few ways to mess with it: adding some mass to the walls of the cab would change the resonant frequency and possibly alleviate the problem... but having a different resonant frequency MAY cause an issue with different sounds/tunes instead.  Ports (basically, holes in the thing) would have an effect on the resonance as well.  Even stuffing part of a blanket or tshirt into the open areas can completely change the frequency response on the system.  Even changing how the speakers are mounted could do the trick.
DietCoke is right though: if you're only running into a problem on one game or specifically one sound, probably the best solution would be to simply edit the offending sound and call it good.  If it's just one file and you can provide it to me and describe the issue in more detail I can take a look and see if I can fix it.  Since you're saying 'hum' I'm wondering if it's actually a problem in the file instead of the build.
