Author Topic: seattle and vegas driver won't sync  (Read 5254 times)
haynor666
  • retro maniac
« on: January 23, 2015, 02:03:11 pm »
My Arcade PC has now enough power to run some seattle and vegas games at 100 % stable but both groovymame and standard mame won't sync with waitvsync and/or syncrefresh. Those game always run at maximum speed or about 199%. This happen on G3258 with Radeon 4350 and 4670k with GTX770. Setting ddraw and triplebuffer does not help either. I can run those games with throttle but then tearing is visible.
  • Last login:Yesterday at 04:39:26 pm
Re: seattle and vegas driver won't sync
« Reply #1 on: January 25, 2015, 04:49:21 pm »
What's the native refresh of those games? Please get a log when possible.
haynor666
  • retro maniac
« Reply #2 on: January 26, 2015, 11:53:28 am »
Gauntlet Dark Legacy: initial 640x480@57 but hardware changes to 511x384@60,386. GM picks 704x480@60,386.
CarnEvil: initial 640x480@57 but hardware changes to 399x256@54,123. GM picks 400x256@54,124
« Last Edit: October 15, 2016, 06:42:37 am by haynor666 »
« Reply #3 on: January 26, 2015, 12:01:59 pm »
Yeah, there are speed issues with the Carnevil game, search this forum and you'll find some reports. I confirmed this too. But I don't know what's the possible reason. Not related to ATI drivers anyway. Need to check official MAME too.
haynor666
  • retro maniac
« Reply #4 on: January 26, 2015, 01:18:30 pm »
Official MAME works almost the same way. Unthrottled and no synced all the time.
« Reply #5 on: January 26, 2015, 01:28:23 pm »
spit ballin ideas here but would changing the dip on the board  (in MAME)  from medium to standard res help at all?>
haynor666
  • retro maniac
« Reply #6 on: February 22, 2015, 07:55:38 am »
Does not matter.
« Last Edit: February 22, 2015, 08:13:09 am by haynor666 »
haynor666
  • retro maniac
« Reply #7 on: April 13, 2016, 09:39:52 am »
I think we might have answer why there are such problems with syncrefresh - http://forum.arcadecontrols.com/index.php/topic,150279.msg1571041.html#msg1571041
intealls
  • Last login:January 16, 2026, 05:54:53 pm
« Reply #8 on: April 13, 2016, 06:31:48 pm »
I'm unable to run Gauntlet Legends consistently at 100% on my 6700k@4GHz, in game it's at 100% but the speed oscillates a bit during transitions etc.
I used -triplebuffer -nowaitvsync -nosyncrefresh. Also did a quick test with standard MAME with gauntleg, and it seemed to perform similarly.
Edit:
I noticed the 199% speed thing as well on the 6700k, I have no idea what's going on. I also benchmarked the G3258, and it probably should be able to run the game at 100%, at least in gameplay, since it was able to run it above 100% speed consistently (see plot).
Edit again:
Regarding syncrefresh, try using -video d3d -nosyncrefresh -waitvsync, this worked for me. I was able to play through the first level without any noticeable drops!
« Last Edit: April 13, 2016, 07:46:35 pm by intealls »
haynor666
  • retro maniac
« Reply #9 on: August 22, 2023, 12:14:10 pm »
Subject is really old but worth noticing that issue is still in mame 257.
Maybe someone found configuration in groovymame to make those games stable ?
I had to disable any kind synchronization in groovmame:
waitvsync 1
sync_mode 0
refreshspeed 0
syncrefresh 0
throttle 1
« Last Edit: August 22, 2023, 12:31:06 pm by haynor666 »
« Reply #10 on: August 26, 2023, 11:54:14 am »
I think I know what happens with these games, will look into fixing it when I have some time.
(Basically these games perform bogus video updates, with empty data).
haynor666
  • retro maniac
« Reply #11 on: August 27, 2023, 01:19:53 pm »
I really appreciate it. Thank you.
