Author Topic: need help - mamewah and noname  (Read 1778 times)
dreamfreak
  • Last login:August 23, 2005, 08:10:58 am
« on: December 19, 2003, 02:32:30 pm »
hi,
I
dreamfreak
Re:need help - mamewah and noname
« Reply #1 on: December 22, 2003, 06:45:45 am »
nobody can help  ???
paigeoliver
  • Awesome face!
« Reply #2 on: December 22, 2003, 07:49:47 am »
Under Windows try setting the soundcard to 1 for soundblaster, or just download the windows version, since there isn't really much reason to run the DOS version under windows anyway.
dreamfreak
« Reply #3 on: December 22, 2003, 08:31:18 am »
can I use the windows version of noname with mamewah ?
Rocky
  • Last login:December 30, 2009, 12:38:41 pm
  • I want to finish my cab before I retire!!
« Reply #4 on: December 22, 2003, 11:28:45 am »
Yes, you can and should use the windows version with MameWah.  MameWah is designed for the windows version, not the dos version.
Good luck
Minwah
    • MAMEWAH
« Reply #5 on: December 22, 2003, 03:28:52 pm »
Good luck
Correct :)  The DOS version should work, although I highly recommend the Windows (commandline) version.
1Spoon
  • Last login:January 17, 2007, 03:07:47 pm
  • Cocktail projekt going on..
« Reply #6 on: December 22, 2003, 06:41:03 pm »
Has NoName got the SmoothMame drivers? (60Hz only I mean)
TheGatesofBill
  • Last login:August 22, 2018, 09:07:04 am
« Reply #7 on: December 22, 2003, 09:45:07 pm »
Nope. I am going to consider adding a command line option to do this at some point, but I need to finish updating to the newest MAME first,
