Author Topic: Sega model 3 Hyperspin Tutorial ??  (Read 10706 times)
lisowskikevin
  • Last login:April 02, 2024, 07:49:55 pm
  • If you take shortcuts, you get cut short.
« on: January 19, 2015, 07:13:14 pm »
Hey everyone, does anyone know of a Hyperspin sega model 3 install tutorial? I have looked high and low for one as I really want to get this emulator working in Hyperspin.
Any help or advice would be awesome!
EMDB
  • Project RetroCade
Re: Sega model 3 Hyperspin Tutorial ??
« Reply #1 on: January 20, 2015, 07:09:34 am »
Just add the emulator's executable and ROM path to the Model 3 wheel in HyperHQ and set execution to normal will get you started.
Afterwards you can start tweaking your setup by write your own Autohotkey script or use HyperLaunch3 if you are and advanced user.
lisowskikevin
« Reply #2 on: January 20, 2015, 08:10:02 pm »
Thanks so much for the quick reply! One thing I wanted to ask....How do you get Hyperspin to run Model 3 if I don't have an .exe file for it? The emulator runs from a command prompt does it not?
EMDB
  • Project RetroCade
« Reply #3 on: January 21, 2015, 02:41:20 am »
How do you run it without frontend? The frontend just replaced you  >:D
lisowskikevin
« Reply #4 on: January 21, 2015, 06:52:24 pm »
hahaha no way that's not a fair replacement......HYPERSPIN  is WAAAAAAY cooler than I am!
delt31
  • Last login:August 01, 2020, 03:11:10 pm
« Reply #5 on: June 29, 2015, 01:40:07 pm »
I have the same issue - how did you guys get this to work?
lisowskikevin
« Reply #6 on: June 29, 2015, 09:45:10 pm »
Nope I just kinda gave up on it. It's unlike any other emu because there is NO DAMN EXE FILE! That drives me crazy about the emu.
delt31
« Reply #7 on: June 29, 2015, 09:53:14 pm »
I hear you.  I've been using that gui front end they released for it but it won't work with hyperspin.  Funny how others have gotten this to work yet no one explains what to do.
« Reply #8 on: June 30, 2015, 07:04:12 am »
I don't use Hyperspin, but am confused by this thread.  I run model 3 games on Supermodel emulator.  It is a command line emulator with an exe and works just like every other command line emulator.  There are thorough instructions on the supemodel3 website.
Is there some newer model 3 emulator?
« Last Edit: July 01, 2015, 01:10:39 pm by BadMouth »
lisowskikevin
« Reply #9 on: June 30, 2015, 08:21:13 am »
Sent from my BLU LIFE ONE using Tapatalk
The issue is that you apparently can't use Supermodel as the Emulator inside of Hyperspin. You have to use the command prompt? I think that's right from what I recall.
« Last Edit: June 30, 2015, 08:27:03 am by lisowskikevin »
delt31
« Reply #10 on: June 30, 2015, 09:18:47 am »
Correct.  I have no problem running supermodel 3 (model 3 emu) outside of hyperspin via command line prompt.  It's having hyperspin do it for me that is the issue.
« Last Edit: June 30, 2015, 10:16:31 am by delt31 »
lisowskikevin
« Reply #11 on: June 30, 2015, 09:40:20 am »
Correct.  I have no idea running supermodel 3 (model 3 emu) outside of hyperspin via command line prompt.  It's having hyperspin do it for me that is the issue.
Ya that's my issue as well. I have searched high and low with no luck as well for this.
  • Last login:Today at 02:27:29 am
« Reply #12 on: July 01, 2015, 12:57:55 pm »
Ugh.... and this is why I don't do front-ends anymore.  Research wrappers, batch files and loaders kids, I'm sure a solution can be found or written.  You shouldn't expect a FE to be a magical device that does everything for you.
EMDB
  • Project RetroCade
« Reply #13 on: July 01, 2015, 01:57:55 pm »
Typing the command line and the parameters in the configuration of HyperSpin (HyperHQ) after creating a new wheel for Sega Model 3 is not that hard  :dunno
delt31
« Reply #14 on: July 02, 2015, 08:24:30 am »
"Typing the command line and the parameters in the configuration of HyperSpin (HyperHQ) after creating a new wheel for Sega Model 3 is not that hard"
Sorry but how would i do this?  I usually have to change that command line each time I want to play a diff game so what is the exact command line I need to include in HyperHQ and where do I put it?  Unfortunately, I have not been able to figure that part out (everything else works though).  Appreciate any insight.
« Last Edit: July 02, 2015, 08:43:30 am by delt31 »
